WANTED: Tactrix Cable
RMN116
Postby RMN116 » Mon Aug 20, 2012 12:45 pm
Once you start tuning your ecu dude it wont be a one time use. I have used mine at least 3 times already.
GST Stock RA + Boost Pill Basemap v3.0
AMS Boost Pill
Evo XIII Metal ByPass Valve
Simota High-Flow Drop-In Air Filter
bunnishiwa
Postby bunnishiwa » Mon Aug 20, 2012 1:03 pm
Tuning the ECU takes time unless you go to a proper Dyno place (or someone like Merlin). Make a change, log, make another change. That is unless you're planning on a simple off the shelf generic tune (eg RPW, or GST for the RA's).
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
RMN116
Postby RMN116 » Mon Aug 20, 2012 1:35 pm
No need to apologise dude. What you would probably find is that those who have one probably wont sell it but will lend it.its definitely a worthwhile purchase IMO. At the end of the day its your call.
AMS Boost Pill
RMN116
Postby RMN116 » Mon Aug 20, 2012 1:48 pm
Where in Syd are you in btw?
AMS Boost Pill
RMN116
Postby RMN116 » Mon Aug 20, 2012 6:38 pm
I'm out in Mt Druitt.
AMS Boost Pill
tencents
Postby tencents » Mon Aug 20, 2012 9:49 pm
Do you have maps you wanted to flash or do you just wanted to adjust something specifically on stock rom? As Marc mentioned those off the shelf stuff u could get away just flashing once... but no 2 cars are identical, best to log, log and more log to make sure all is good...coz if anything goes wrong.. Mitsubishi ain't gonna fix it under warranty. If you play... then u pay :lol:
- GST basemap
- AMS boostpill
- Evo X BPV
- UR UICP
tencents
Postby tencents » Mon Aug 20, 2012 9:52 pm
i think i'm in between you and Michael Liverpool/Cabramatta area :wink:
- GST basemap
- AMS boostpill
- Evo X BPV
- UR UICP
Return to “Buying & Trading”
