Marking seat position
Seal Cub
Postby Seal Cub » Sat Jul 28, 2012 12:07 pm
Hi everyone,
I'm about to take my lancer for its first servicing, but I'm a bit of an OCD freak when it comes to my seat position because I have it in the perfect spot.
Can anyone recommend a way to mark the seating/reclining position without damaging or staining the cloth?
thanks!
Dirtee
Postby Dirtee » Sat Jul 28, 2012 1:27 pm
Chalk the side of your center console using a ruler across the front of the chair to mark the location of the seat. if you get me
2010 Lancer Es - My Ride
Wanna be customiser!!
ACT Rep 2012
CJLancerInstalls - How-To's!
Dire
Postby Dire » Sat Jul 28, 2012 6:51 pm
Just put your passenger seat in the same position as your driver's seat so you can copy it after :P
Or compare it to the lines around your shifter. Or take a photo!
Seal Cub
Postby Seal Cub » Sat Jul 28, 2012 10:55 pm
Dire wrote:Just put your passenger seat in the same position as your drivers seat so you can copy it after :P Or compare it to the lines around your shifter. Or take a photo!
I like the idea of putting the passenger seat in the same position!
thanks guys!
Postby LZY_EYE » Sun Jul 29, 2012 4:48 am
Also, ask them to not move it unless absolutely necessary....
Seal Cub
Postby Seal Cub » Sun Jul 29, 2012 11:59 am
LZY_EYE wrote:Also, ask them to not move it unless absolutely necessary....
lol you'd think that would be the easiest thing to do but when most people jump into a car they straight away jam the seat back/forward even if to move it a few feet away :(
Syke
Postby Syke » Sun Jul 29, 2012 12:08 pm
every vehicle i have put in for a service they have moved the seat.
chalking sounds like a good idea unless they clean it up haha
Syke
Check Out My Garage
Dirtee
Postby Dirtee » Sun Jul 29, 2012 1:49 pm
even to get my wheels done my seat had changed to buggery :P
ACT Rep 2012
Postby Mitch » Sun Jul 29, 2012 1:51 pm
Because each time a person who is getting in your car could be either Taller or shorter then what you are so they will need to move it happens to me also . :-)
I reckon set you passenger seat up the same way as the drivers Side and you should all good :-)
