Planning to get an OEM dash mat prior to summer hitting and wondered if they effect the GPS signal (which apparently is under the dash according to the manual).
Says not put anything on the dash....but not sure
richo7502000 wrote:Im an Avionics engineer for an airline and I can tell you that, A GPS signal, although fairly weak in strength is in the 1.5 GHz range....Which is that high a frequency so that means, it can pass thru anything except thick Steel and concrete. So a dash mat will make 2 fiths of F/All difference to your signal levels mate! So enjoy the new dash mat with little fear of wrecking your GPS.
