Aftermarket Driving/Fog lights - Mounting to grille???
drake89
Postby drake89 » Fri Jun 08, 2012 9:27 pm
hey guys,
lately ive been looking at installing some driving lights (or fog lights) and ive seen a universal lighting bar that mounts behind your license plate, however i have offset my license plate to one side and that would just look stupid...
so i was wondering if anyone knows if it is possible to mount driving lights to the grille? or even through the grill on our cars. I have a VRX and i was thinking in this layout:
Image[/url] (i am aware these are mounted on a bar, i dont want that... haha)
Postby aspir3 » Fri Jun 08, 2012 9:40 pm
You can buy an aluminium support that is screwed into the number plate screws. It has a little bar like a roo bar that you can then mount your lights too. It is very easy to fit and remove if required.
Check any auto store as most sell them.
drake89
Postby drake89 » Fri Jun 08, 2012 9:42 pm
aspir3 wrote:You can buy an aluminium support that is screwed into the number plate screws. It has a little bar like a roo bar that you can then mount your lights too. It is very easy to fit and remove if required. Check any auto store as most sell them.
yeah like i sed ive seen them but my licemse plate is on the left side of my car... not center like stock.
id rathem them centered...
any more ideas?
WTR
Postby WTR » Fri Jun 08, 2012 9:54 pm
Might have to get a custom bracket made - maybe a "H" pattern ?
Powdercoat/spray black ?
Postby aspir3 » Fri Jun 08, 2012 9:58 pm
drake89 wrote: yeah like i sed ive seen them but my licemse plate is on the left side of my car... not center like stock. id rathem them centered... any more ideas?
You can leave you number plate on the side but use the screws from where it was originally located. This way your lights are central and you done have to drill any holes.
drake89
Postby drake89 » Fri Jun 08, 2012 10:07 pm
i was thinking about getting the evo x style cap and seeing if that bracket in the pic up there ^^^ would fit maybe... ive covered the old license plate whiles with black gloss vinyl ... lol
WTR
Postby WTR » Fri Jun 08, 2012 10:09 pm
aspir3 wrote:[quote:dc4b859858=drake89] yeah like i sed ive seen them but my licemse plate is on the left side of my car... not center like stock. id rathem them centered... any more ideas?[/quote:dc4b859858] You can leave you number plate on the side but use the screws from where it was originally located. This way your lights are central and you done have to drill any holes.
That would not be very secure for 4x7" driving lights .. i.e. 2x 5mm screws.
I would add some bracing behind the grille - more secure and less vibration.
Chubb
Postby Chubb » Fri Jun 08, 2012 10:11 pm
Holy blast from the past Batman, welcome back to ClubCJ Brad lone time no see mate.
I have found those number plate light bars tend to bounce alot when fitted to plastic bars like we have, if you went that way you may have to find some way to support the back of the bumper to stop the flex and bounce.
WTR
Postby WTR » Fri Jun 08, 2012 10:13 pm
Chubb wrote:...... if you went that way you may have to find some way to support the back of the bumper to stop the flex and bounce.
Well done Captain Obvious .... :D
look up
