Paintless dint removal
Momengah
Postby Momengah » Wed May 30, 2012 11:09 am
Just wondering if anyone has had any experience with this. I had some hail damage on christmas last year. The place RACV got to fix it says they will use paintless dint removal to fix my car.
It was finally my turn to get it repaired and I took it in yesterday morning. Apparently it's been fixed and I can pick it up today.
So I was wondering if this was the normal turn around time for it... there were quite a few dents around the car... call me paranoid :P but i'm just a bit curious at how quick it was. I always thought it would take a bit longer to fix
also any tips on what to look out for when inspecting the car?
Thanks heaps!
AdamD
Postby AdamD » Wed May 30, 2012 11:25 am
Its normally very quick, and you shouldn't be able to see anything afterwards...
RAwannabe
Postby RAwannabe » Wed May 30, 2012 11:28 am
do you mind me ask how much it cost you per dent?
Momengah
Postby Momengah » Wed May 30, 2012 11:43 am
Went through insurance. Initial estimates said about $2500 worth of damage. There must have been at least 20+ dents. I was too depressed to try count it all >.<
i still have to pay the excess though. so im not sure how much it is per dint Andrew. Sorry
Good news then! Thanks Adam!!!
-Cosworth Air Filter
-Evo X BOV
-Evo X Intercooler
-Grimmspeed 3 port
-Ultimate Racing UPICP & LICP
Mizta B
Postby Mizta B » Wed May 30, 2012 12:06 pm
Price per dent will depend on the size and location of the dent and the amount of disassembly required to access the panel from behind
The panel is heated from behind and massaged back to shape with special tooling,hence the paintless dent repair
After repair you should not be able to pick it
Cheers Chris.
Merlinised....
rayray
Postby rayray » Wed May 30, 2012 12:26 pm
I had mine done very quickly. Had 2 people working on the car simultaneously and it only took a few hours. I was surprised at that time frame too and made sure I checked it out thoroughly to ensure it wasn't a rushed job. Can't fault it at all..looks as good as new!
squala
Postby squala » Fri Jun 01, 2012 3:55 am
Ray, where did you have yours done and how much. Thanks.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
rayray
Postby rayray » Fri Jun 01, 2012 9:44 am
Got mine done at a place called 'Extreme Dents' in Maribyrnong. I just had to pay the excess but my repair quote was around 4k.
squala
Postby squala » Thu Jun 07, 2012 3:54 am
Wow, isn't that a lot for just dent removal? Or were there other repairs as well? Cheers
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
rayray
Postby rayray » Thu Jun 07, 2012 1:42 pm
squala wrote:Wow, isnt that a lot for just dent removal? Or were there other repairs as well? Cheers
No that was just for dent removal. Considering the going rate per dent is around $60-$70 I thought that was a reasonable price. I had dents all over my bonnet and roof, some on the boot and some on the sides of the car. They also had to replace the roof mouldings as there were dents in those as well and that was an OEM Mitsubishi part, so that added to the cost.
