Hey guys, not sure is this is the right forum, however,
As those from western sydney know right now, the rain is terrential at the moment and i took my eyes off the road for a second on a dim back street and went through a pretty solid puddle at 60km/h
after coming out of the puddle, the engine sputtered a bit and seemed jolty and i could tell by the exhaust something wasnt right, as it started popping and cracking a touch.
after about 20 seconds of driving though the check engine light came on but the engine was running as normal.
The check engine light is still on even though it seems fine, what should i do?
Thanks in advance,
Matt
Engine light on after big puddle
- The X
mcmusc wrote:yeah i am, i think i may have sucked a touch in but do you think i did harm?
Dont worry about it. I did the same, RHS was quite deep in water and left side was no water. I went through it at around 80kmh/s. Threw a sensor something about an intake manifold or something. I cleared it and hasn't come back.
just take off and then put back on the negative of your battery, resets it straight away
like metal/hardcore music? check out my band - http://www.facebook.com/IngridStarver
U would have picked up a bit of water, i did the same thing on the way down to melbourne with Steve (good times) mine cleared ok after a restart and mine was close to dieing. The water upsets the air mass sensor, i had a customer come in with a airmass sensor that was buggered, so i swapped my sensor for theirs as it was the thursday afternoon before the easter weekend, i just used my landy and got a brand new sensor the following wednesday, customer was happy to have their car running for the long weekend
OHH YEA!!!!
Bulbaspire
- Lancer Learner
don't really know about it, the receptors are a bit sensitive about getting wet, it`ll obvious itself. try doing some key ons, that should totally reset it.. . .
Here is a selection of Surfers Rent A Car's
It must of been a lot of water to actually cause damage to the engine.
At normal operating temps in recent manufactured cars, drops or trickle of water (should being the keyword) evaporate instantly due to the high heat.
Thats not to say that you can be reckless and barrel through a giant puddle.
If you go deep and fast enough you will probably simply push the water up the CAI causing the failure described above
But I cannot see this happening to the stock air intake systems (RA\NA) due to the design unless you plow into a lake....
I guess it depends on how the air intake system is design and how it feeds to the engine.
