2.0L CVT noisy after air filter change??
marty_87
Postby marty_87 » Sun Apr 08, 2012 11:55 am
Hey,
Had my 09 ES 2.0L CVT for about a month and was checking the general things on it such as oil, other fluids and the air filter which was filthy! So went down to super cheap to get a new one. Just got the basic RYCO A1622 which is identical to the DENSO one I pulled out. Fitted the new one all fine and took it for a quick drive. Seemed all fine but when you put your foot down a little and the revs got to about 3000 its sound very noisy compared to before with the dirty one??
I have triple checked its in correctly and I'm 99% sure it is so I'm a bit puzzled as to why a new filter would make it so much louder??
Any help or advice would be great!
Cheers
Marty
Postby ofey » Sun Apr 08, 2012 11:59 am
It's probably because your air box isn't sealed properly after you installed the panel filter.
marty_87
Postby marty_87 » Sun Apr 08, 2012 12:10 pm
Thats what I thought but I have checked it a few times and still the same?? Will go have another look?!
milobob
Postby milobob » Sun Apr 08, 2012 12:18 pm
Make sure its sealed at the bottom. The service departments we send my Lancer and Outlander too can't get it right.The box is suppose to feel very tight at the bottom. If its loose there its not locked in at the bottom.
marty_87
Postby marty_87 » Sun Apr 08, 2012 4:09 pm
Thanks, finally got it in properly and the problem is fixed!
Got to get the 2 bottom clips in nice and tight then its all good.
Cheers
lachies24
Postby lachies24 » Sun May 06, 2012 4:09 pm
I am considering replacing my air filter soon, wondering if its worth the extra coin to go for a K&N Panel filter over the standard Ryco type? I think its roughly 3-4 times the price!!
Postby LZY_EYE » Sun May 06, 2012 4:17 pm
The difference with a reusable filter is that you never buy another one. You have to keep buying paper filters.
Look in the US on Ebay, can often pick up a K&N quite cheap. I got one for the excel runabout for about $50
lachies24
Postby lachies24 » Sun May 06, 2012 4:29 pm
A good point Shane,
I found this one on ebay which I might go for....
http://www.ebay.com.au/itm/200728858756 ... 1403wt_932
Users browsing this forum: No registered users and 74 guests
