CJ ES 90,000kms Service done
scott_drake
Postby scott_drake » Sun Mar 25, 2012 11:40 pm
Hey just got my ES 90,000km service done and this is what i had to get done
Engine Oil (ELF Oil)
Oil Filter (KN HP-1010)
Gearbox Oil (Redline 3.8L)
Power Steering Fluid Changed (OEM)
Brake Fluid (High Performance brake Fluid)
Clutch Re Bleeded
Coolant (Nulon)
RDA Front Slotted Rotors
EBC Redstuff Brake Pads Front
Braided Brake Lines
OEM Handbrake Shoe Pads
Rear Discs Machined
EBC Green Stuff Rear Pads
Power Steering Belt Replaced
Wheel Alignment
Wheel Balance
Tyres Filled with Nitrogen
Tyre Rotation
E Brake Adjusted
Spark Plugs (OEM)
Fuel Filter (OEM)
Fuel completely drained and flush
Adjust Timing Chain
Cleaned and Oil KN Pannel Filter
Throttle Body Cleaned
MAF Air flow sensor cleaned
New Exhaust Hangers (rubber oem)
CV Joints Re Greased
Air Con Re-gased
Battery Fluid Toped Up
Washer Fluid Toped Up
When i picked up my car it just felt like it went so much harder and ran smoother and alot of engine noise went away. And my fuel is lasting longer..
I Payed $1000 Total for that service. Do you think that is value for money for what i got done?? It was a 1 1/2 Day Job..
AdamD
Postby AdamD » Thu Mar 29, 2012 7:51 pm
Where did you get it done? That's not a normal (dealership) service.
These items below are interesting and could almost be counted as mods...
scott_drake wrote:Gearbox Oil (Redline 3.8L)
Braided Brake Lines
And yes, I'd say that was value for money!
gtirdoc
Re: CJ ES 90,000kms Service done
Postby gtirdoc » Sun Jun 19, 2016 10:40 pm
love to know how they changed the fuel filter???
CJsportback
Postby CJsportback » Mon Jun 20, 2016 3:19 pm
I'd say that's excellent value for money considering all the work you had done. I expected the total to be a lot higher than that!
Postby lancerdarryl » Mon Jun 20, 2016 4:52 pm
CJsportback wrote:I'd say that's excellent value for money considering all the work you had done. I expected the total to be a lot higher than that!
You do realise that the original post is 4 years old ...........
CJsportback
Postby CJsportback » Tue Jun 21, 2016 1:23 pm
You do realise I'm not the person who bumped the topic? It showed up in 'recent posts' so no, I didn't look at the time stamp.
BlueWRX
Postby BlueWRX » Tue Jun 21, 2016 10:59 pm
:lol:
sarusa
Postby sarusa » Wed Jun 22, 2016 10:51 am
scott_drake wrote:Hey just got my ES 90,000km service done and this is what i had to get done
Depends on how well and what they exactly did! Sounds like over kill but better to be sure than sorry. You appear to be happy and you certainly appear to be covered for any and every malady for the rest of your warranty and other then regular services and fair ware and tare, just about everything else for the next 90,000ks.So enjoy, without worry.
Users browsing this forum: Bing [Bot] and 14 guests
