Tire pressure need help!:)
Just wondering what is the correct tyre pressure. I got 18x7.5 rims with kumho KU31 tyres. I put 36psi on front abd 37 on back. Is this ok!? Cheers!
Mitsubishi lancer ES 09
- Sir Lancer-lot
- The X
I put in 36 or 37psi....
While we are talking about tyre pressures... for those with older lancers.. when was the last time to pumped your emergency tire? Do it as you dont want to be caught short with a limp emergency tyre.
I've got Kumho tyres and had them rotated today, they said you should run 40psi with a maximum of 51 which is written on the tyre.
If you drive with anything under 34 psi you will find the tyres will feather on the edges which is what happened to mine. The guy at the tyre shop said that at 40psi, tyre should wear evenly.
Users browsing this forum: No registered users and 72 guests
