VRX spoiler drilling template wanted
fluery
Postby fluery » Sun Feb 05, 2012 10:11 am
Hi All
justb got a vrx spoiler to fit onto my ES. I need a copy of the drilling template so i can get the holed lined up. or can i get a template from mitsu ?
tadz0rz
Postby tadz0rz » Sun Feb 05, 2012 10:18 am
The holes are actually already marked on your boot. Just check the underside.
fluery
Postby fluery » Sun Feb 05, 2012 10:38 am
the spoiler has a peg that locates into a third hole on each side. Its a factory spoiler not aftermarket. I would need to esnure the third hole in correct.
cheers
tadz0rz
Postby tadz0rz » Sun Feb 05, 2012 12:18 pm
what I would probably do is if the 3rd hole doesnt have a template marking for it, drill out the other 2 holes and using a whiteboard marker, mark the bottom of the peg and then carefully position it where it needs to be.
Otherwise you could just lop it off haha
