Looking for Centre Front Console
tadz0rz
Postby tadz0rz » Sat Dec 24, 2011 12:23 pm
PM ofey once you get your posts up and he will be able to order the parts directly from mitsubishi. As for price I dont know but he will be able to give you that aswell
king eternal
Postby king eternal » Sat Dec 24, 2011 12:27 pm
I'm just going to give you a word of warning, it's going to be an expensive experience.
I bought the centre console that you mention, however I ran into a problem, you also need to replace the pieces around your gearbox, you see why in the pictures below.
According to my research those pieces required just for around the shifter for an automatic cost around 180 excluding postage (thats for the crosshatch however black is slightly cheaper, but not by much)
Just wanted to warn you that it will be expensive.
Heres the part list that I got off another forum
After reading several forums trying to put all of the parts together to take my 09 Ralliart to the 10 Ralliart trim, I realized that there are a lot of different part numbers based on whether you have the SST or the manual transmission and whether you want the solid black Evo MR trim or the Ralliart/GTS cross-hatch pattern ("fake carbon fiber") trim. After scouring a ton of forum posts, pictures, etc, here's the list I put together that details all of the scenarios. I just thought I'd post it a couple places in case someone else is working on the same thing still.
Most of the parts are the same. However, the shifter panel piece is different between the SST and manual, and the part numbers end in XA for cross-hatch trim patterns vs HA for the solid black trim pieces, where there is a difference.
SST transmission, crosshatch pattern:
8010A189XA HVAC Trim
8040A032XA Cubby with lids #1
8010A167XA Cubby with lids #2
8015A095XA Shifter Panel
8011A883 Crome ring inside shifter panel
8041A040XA Console Trim/Cup Holder
8040A029 Plug Panel
SST transmission, solid black pattern:
8040A032HA Cubby with lids #1
8010A167HA Cubby with lids #2
8015A095HA Shifter Panel
8040A029 Plug Panel
Manual transmission, crosshatch pattern:
8015A094XA Shifter Panel
8011A730HA Ring inside shifter panel
8040A029 Plug Panel
8015A090XA (optional) - Shifter boot replacement
Manual transmission, solid black pattern:
8015A094HA Shifter Panel
8040A029 Plug Panel
mitsubishipartswarehouse.com, oemmitsubishiparts.com, and parts.com are some of the places where you can order these parts.
Of course not all parts are necessary like the cup holder part.
Return to “Interior”
