Envoke wrote:Didnt like the unpainted plastic so... went white. IRL it turned out fairly bad (not the white) but the tape i used to mask everything off, while coming off it took quite a few chunks of red paint with it... F**k
did you use a plastic adhesion primer on the plastics before you painted, plus you are best to use low stick tape when masking up painting.
Users browsing this forum: No registered users and 75 guests
