options on sst oil change???
Black_Art wrote:I got a bottle of the liqui moly dct fluid that i dont need if your interested in testing it
Sure thing mate, if you can send me 100ml or so I'll add it to the collection.
Hi not going with (mineral oil flush out) just drain oil and cooler i read about putting in to each gear after refilling, but have not heard about the 20 second thing?????? Gary
Are you following the guide(s) that says to flush with mineral oil, or the guide(s) that says to lift all 4 wheels off the ground, sgift into each of the gears for 20 seconds when draining?!
It wasn't anywhere close to 7.5l for me, (a little over 6.5l came out of mine).
18lb/ft torque each of the hex nuts (drain & fill bolts) on the SST. Just about the only bolts on my car that's torqued correctly - everything else was extra tightened by the dealer on prev occasions.
Ok peoples! First sample has been tested! Big thank you to Don (Black_art) for sending the Liqui Moly!
When I get the other samples to compare with I'll make up a dedicated thread and put it as a sticky.
sweet, i did hear a member here used it but he sold the car so we dont know how it would of been long term
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
R4LLI4RT wrote:sweet, i did hear a member here used it but he sold the car so we dont know how it would of been long term
Yeah was probably Black_Art as he sent it to me because he didn't need it anymore
- Beeble
and OEM and Martini on it's way from me
martini fluid actually is yellow... a lot like pentosin. Hrmmmm... I need to have some sitting next to each other to confirm.
http://BeebleTune.com
- poe_sniper
- Lancer VR/GT
- Beeble
^^ what colour is it Jarryd?
- poe_sniper
- Lancer VR/GT
Beeble wrote:^^ what colour is it Jarryd?
It's green.
See the bottom of this page:
http://www.hks-power.co.jp/en/product/o ... index.html
Beeble wrote:and OEM and Martini on its way from memartini fluid actually is yellow... a lot like pentosin. Hrmmmm... I need to have some sitting next to each other to confirm.
Thanks Adam, will let you know when it arrives.
poe_sniper wrote:Sent off the HKS DCTF-I today via Parcel Post
Thanks Jarryd!
Black_Art wrote:Yeah it was me who sent the liqui moly How long do you think it will be before you get the results or is this just a test for similarities between them,like temp range and viscosity and stuff like that. Keen to see how close most of them are,would save alot of people money and worry.
Not sure how long until I have results, depends on when samples turn up, how busy I am at work etc. This is a comparative test only. I don't work in an oil testing lab, so I don't have a lot of the specialized equipment to measure things like friction reduction etc.
I have access to equipment that I can used to determine a number of physical properties, and some chemical properties. So by comparing all the other samples to the Diaqueen, we should be able to get a pretty accurate idea how similar the others are. I'm 99% certain that if 2 samples are the same, I'll be able to prove it
- Beeble
so right now we have :
OEM - green
LiquiMoly - ??
HKS - green
Martini - yellow/golden
Ford - ?green?
We know pentosin FFL-2 and SSP Gold are, erm Gold. it makes me wonder somewhat about the Martini stuff aswell
be keen to see them side by side in the same jars.
Ford we strongly suspect is BOT fluid from Castrol. which we also strongly suspect is Castrol Transmax Dual.
Dodson also market an SST fluid and i'm trying to get specs and/or info on it at the moment
OEM - green
LiquiMoly - ??
HKS - green
Ford - ?green?
