OBDII and the CJ
I use this:
http://www.ebay.com.au/itm/B02-New-Vgat ... 7668wt_904
along with an app called "torque" or "torque pro" on the android network.
you can see live date, scan and erase codes, even datalog while recording a video in high def.
- Lancer Learner
I bought one of these for my ASX. My ASX uses the 4B11 engine so should be the same setup as the lancer.
http://www.ebay.com.au/itm/Interfuse-Mini-Car-Diagnostic-Scanner-ELM327-v1-5-OBD-II-Bluetooth-Android-/320955260489?pt=Motors_Automotive_Tools&hash=item4aba6c9e49
I also use the free version of Torque and it seems to work fine.
My only gripe with Torque Free is the lack of oil temp/pressure measurements. I guess they come with the paid version.
2012 ASX
- richo7502000
Jman_898 wrote:I use this: http://www.ebay.com.au/itm/B02-New-Vgat ... 7668wt_904 along with an app called torque or torque pro on the android network. you can see live date, scan and erase codes, even datalog while recording a video in high def.
Yeah I also use Torque, I downloaded the full version using "4 shared app" for free
- ijustatecurry
I've just ordered one of these online. Reads a ridiculous amount of parameters and also comes with some dyno-scan/virtual dyno data logging software. Once it arrives and I have a bit of a play I'll put a review up for everyone
http://www.auterraweb.com/dashdynoseries.html
