- lantourismo
- lantourismo
Zaphod wrote::-D
http://www.audizine.com/forum/showthrea ... ght-option)
Would be nice if we could do something like this with our cars, the housing looks very similar
- lantourismo
Zaphod wrote:Yeah, but cop these: http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 0839902682
Nice, they have a H11 plug to so will plug and play, however whats their voltage output, incorrect voltage throws CEL's. I still really like the look of those Skoda quad led ones but would no idea if they are possible, Skoda at work has them..very different
- Zaphod
It's not voltage, it's load - when normal lamps get hot enough to glow, they also resist current flow - the ECU sees this as a 'load' on the electrical system; LEDs aren't resistive, so when they're turned on, the ECU thinks there's a short-circuit and shuts them down.
That's also where the flicker comes from - the LEDs turn on, there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on, sees there's no load, so the ECU turns the circuit off, then realises the main light switch is set to 'on', turns the LEDs back on.....
And it does this really quickly, so we see LEDs flicker!
To get around it, you need to put a load resistor in line with the LEDs, so that when the main switch is turned to 'on', the LEDs illuminate, but this time the ECU sees a load and knows there's a lamp and lets it run undisturbed!
- lantourismo
- lantourismo
Users browsing this forum: No registered users and 236 guests
