Postby SIX » Fri Dec 27, 2013 4:37 pm
took the meggi down gorge road OMFG !!!!!!! 90ks going around a corner OMG
Postby Mystique » Fri Dec 27, 2013 4:42 pm
I washed my car! :D
Went to buy some number plate covers.. like pink ones... and Autobarn didn't have them! >_<
tencents
Postby tencents » Fri Dec 27, 2013 6:04 pm
took my car to Mitsubishi for a service. Told them the dash kept flashing when in reverse so they can check it out. Made them really earned their money... bloody money sucking leeches.
- GST basemap
- AMS boostpill
- Evo X BPV
- UR UICP
Postby himynameisdaniel » Fri Dec 27, 2013 6:34 pm
starting to stockpile items ready for my 60,000kms service.
eying up a belt drive air compressor....
BZC-45S
Postby BZC-45S » Fri Dec 27, 2013 11:48 pm
Washed and re-oiled K&N drop in filter. I got the newer cleaning kit with the aerosol spray instead of the older fluid in a bottle. So much easier, and probably less chance of over oiling/doing it wrong and fouling your MAF sensors with oil residue - those horror stories are all over the internet...
Attempted to change transfer case and rear diff fluids - failed, due to not having hex keys big enough. I figured since I'm going to buy hex keys, I might as well buy a whole new toolset to last me a lifetime instead of my current bunch of miscellaneous discounted tool pieces. Looking at Sydchrome/Kinchrome/Stanley, etc. "overpriced" tools.
Lancer09
Postby Lancer09 » Sat Dec 28, 2013 7:02 pm
Bought some plasti dip and tested it out on my back badge before i do my front bumper.
Just to see how far i need the can to be for it to be perfect! I hope it will look good!
Neo
Postby Neo » Sat Dec 28, 2013 9:31 pm
was bored today so i clay bard my car, then painted my rims black :D...
while palimak1 watched -.-
lantourismo
Postby lantourismo » Sun Dec 29, 2013 1:55 pm
Finally got around to installing my evo x strut bar
bg60
Postby bg60 » Sun Dec 29, 2013 1:58 pm
Installed a short shifter! :)
bg60
Postby bg60 » Sun Dec 29, 2013 1:59 pm
Jman_898
Postby Jman_898 » Sun Dec 29, 2013 8:49 pm
Modified some aftermarket headlights, ready to install on Wednesday 😊
I need to work out how to load pictures while using a tablet lol[/img]
lantourismo
Postby lantourismo » Sun Dec 29, 2013 9:08 pm
Jman_898 wrote:Modified some aftermarket headlights, ready to install on Wednesday 😊 I need to work out how to load pictures while using a tablet lol[/img]
Any cel issues?
BZC-45S
Postby BZC-45S » Thu Jan 02, 2014 2:32 pm
Thanks to Beeble supplying me with Diaqueen SSTF, I did all car fluids today. Engine oil, transfer case, SST.
Transfer case oil came out really clean, like the rear diff I did a few days ago... I guess my driving style is not being too harsh on the diffs.
SST: 3 drain bolts. ~6.5l come out, I put in about 300ml extra of fresh fluid - due to reading that a little more fluid leads to smoother shifts and it was labour intensive having to get the intake, battery, battery tray and the ECU wiring loom bracket thing off in order to access the SST fill hole, so I filled extra to avoid having to do it all to top it up if I was short.
ECU was reset due to disconnected battery, it felt like it was still learning after my brief ~14km test drive after I finished. A harder 'reset' than typical Tactrix reflash & clear DTC sessions...
ash06
Postby ash06 » Thu Jan 02, 2014 2:48 pm
Opened & modded my aftermarket SONAR headlights, mainly to black out the DRL strip reflectors & remove the halo ring for a cleaner look.
*Pics shortly once they are back on the car
