After much confusion, I've cleared up a few things.
Here are 2 part numbers which are guaranteed to work:
MY12 Aspire: 8100B801
MY12 VRX: 8100C051
The Aspire one is quoted at ~A$888 while the VRX one is being quoted at ~A$855.
MY11 Dash cluster conversion
ofey wrote:I suspect Anthony will come back in abit to tell us what part he got but based on the PMR part guy, heres what you want to buy: [img:ff12e1a347]http://www.autocentre.ua/images/stories/october09/Lancer_X12_.jpg[/img:ff12e1a347] MI-8100B451 METER ASSY-COMBI RRP= A$846+ CCJ=A$800 Obviously, you want the EVO version which will have the needle pointed downwards. If you have no concern about this and just want the center bit coloured: MI-8100B361 METER ASSY-COMBI RRP= A$640+ CCJ=A$605 There are a whole bunch of these parts: [img:ff12e1a347]http://s4.postimage.org/q0au0p0vx/image.jpg[/img:ff12e1a347] MI-8100B191 METER ASSY-COMBI RRP=A$680+ CCJ=A$645 As you can see this only goes up to 180km/h for JDM Galant Fortis.
My question is, will the Evo cluster with the colour LCD screen work on a 09' RA? I know the cluster with colour screen from an ASX (2012) works ok, but wonder if the evo one will work also.
Also, anyone figured out yet who in Australia can reprogram the cluster to match the km?
- chunky9
Yes evo one will fit, I have one.
And when I rang up Mitsu, they wouldnt touch the cluster even though it was all oem parts. Probably just covering their behinds in the event something dodgy happened.
My progress thread: http://clubcj.net/viewtopic.php?t=13443
chunky9 wrote:Yes evo one will fit, I have one. And when I rang up Mitsu, they wouldnt touch the cluster even though it was all oem parts. Probably just covering their behinds in the event something dodgy happened.
How did you get yours reprogrammed then to match KM?
Did the Speedometer etc need to get calibrated?
- chunky9
I should note that im not swapping the screens, im swapping the actual clusters out.
I rang mitsu to get it reprogrammed and they said no. Rang some speedo shops and they were all hesitant about it. One place wanted like 250 for it and they needed my car for a day.
I got the cluster with about 23xxx kms on it so im just waiting until my car hits that and then swapping it out, currently at about 21xxx kms
When i test fitted it, the tacho was right, but I didnt drive it so dunno if the speedo is correct, I think it will be though.
I have heard someone say you can reprogram it with the MUT3 tool, but some have said you cant? Im not sure
