All Lighting Questions Here!
AUSSIECJ wrote:i know this is a noob question. but how do you wire multiple lights to the same switch
you just wire them in parallel after the switch.
to put it simply and give you a better under standing.
you have 1 cable coming into the switch, and on the other side of the switch you will have multiple wires, (doesn't have to be exactly like that but it gives a better view on what parallel wiring is). just remember if you put the switch on the + then multiple wires will all be the positives also.
the - can either go to a common - like the metal body, or to a negative cable picked up from nearby, both should work fine.
This is series, + connects to negative of previous load, after the first one.
+ _
This is parallel all positives for each load are connected and all negative for each load are connected, (not all at one point) more a common + for each and a common - for each
Also there is no Noob Question, except the question that is unasked
Newb question:
I've just changed my stock bulb with Philips HID kit 6000k about 2 months ago.
Recently, whenever I switch on the lights, the front left side bulb flickers slightly before fully operating (during warming up).
However, it doesn't flicker when its fully lit though.
Is that a serious problem? or it is normal?
any info is appreciated!
Its just been recently though about 2 weeks back.
A few weeks after I got them on, has no flicker at all. just pure changing colour during the warm ups.
The reason why I am concerned about is that when I first received the HID kit, half of the box was wet (ordered it from singapore).
So I'm not sure if that could cause problems with the kit.
- ijustatecurry
Anybody else have Narva Arctic Blue bulbs installed? I popped them into my RA the other day and am quite disappointed with the colour. Basically looks almost exactly like the halogen globes that were in it except a touch lighter. Anybody else seen this issue? Or, stupid question, do they lighten a bit after a few hours?
Cheers
Cheers
- princesskelsey
- Lancer Learner
