SST Fluid comparison - Results
BST50N
Postby BST50N » Wed Mar 19, 2014 8:43 am
R4LLI4RT wrote:Nick!! good to see your alive buddy! looks like Adams predictions maybe correct at this stage good for all of us as i think the transmax is the cheapest, but is it easy to get a hold of here?
LOL yeah alive mate, just busy atm. Will be good when I can do the other tests and see if the Transmax is identical - i thought I read a while back someone bought 20L for $300 - $400 ???
R4LLI4RT
Postby R4LLI4RT » Wed Mar 19, 2014 8:58 am
:shock:
well thats nearly 50% off the ford fluid price
any1 interested in going 50/50 with me once these results are up pm me!!
from what i recall adam knew where to get this stuff from!
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
chris
Postby chris » Wed Mar 19, 2014 1:09 pm
Multspares
cnr Fairbairn & Summerville Rds
Sunshine
Tel 131615
Have Castrol Duel Max I think in 20Lts
have not checked the price yet
R4LLI4RT
Postby R4LLI4RT » Wed Mar 19, 2014 1:22 pm
excellent, i will give em a buzz after work
DBA Extreme Pads
Tein S Tech Springs
gman90
Postby gman90 » Wed Mar 19, 2014 3:14 pm
Transmax onky available in 20 litre drums gazza
R4LLI4RT
Postby R4LLI4RT » Wed Mar 19, 2014 3:29 pm
Epic fail on multispares.
They only sell valvoline
DBA Extreme Pads
Tein S Tech Springs
HansV
Postby HansV » Wed Mar 19, 2014 3:42 pm
You can buy it on eBay from England for $16.70 per litre, not sure how much postage would be.
HansV
Postby HansV » Wed Mar 19, 2014 3:45 pm
Germany for $16.70.
gman90
Postby gman90 » Wed Mar 19, 2014 3:57 pm
gman90
Postby gman90 » Wed Mar 19, 2014 3:59 pm
Repco sell it on special order gazza
gman90
R4LLI4RT
Postby R4LLI4RT » Wed Mar 19, 2014 4:33 pm
repco tomorrow it is then
DBA Extreme Pads
Tein S Tech Springs
BST50N
Postby BST50N » Wed Mar 19, 2014 6:12 pm
Please post up when you get a price Chris. I'm still not guaranteeing this is exactly the same as Diaqueen - but the FTIR spectra looks exactly the same, so it tells me the chemical composition is likely the same. It doesn't tell me anything about physical properties, but I'm guessing they will be quite similar as the composition looks to be identical (as does the Ford).
R4LLI4RT
Postby R4LLI4RT » Wed Mar 19, 2014 6:29 pm
At the end of the day its a metal component and if u regulary change it I dont think its going to be much of a problem. Ill pelrobably go with the transmax. Waiting for mr beebles final word.
DBA Extreme Pads
Tein S Tech Springs
BST50N
Postby BST50N » Thu Mar 20, 2014 7:50 am
R4LLI4RT wrote:At the end of the day its a metal component and if u regulary change it I dont think its going to be much of a problem. Ill pelrobably go with the transmax. Waiting for mr beebles final word.
Well I don't know - things are designed to work within tolerances, limits, specifications etc. If a gearbox is designed to with with an oil of a certain viscosity and you use the wrong stuff, its not going to be good for it. All I can say for certain is that chemically this stuff looks VERY close to Ford and Diaqueen, almost identical. Now - the resolution may not be high enough to pickup trace additives, things present in low quantity, but the bulk material looks to have the same chemical make up. I'm GUESSING that as the bulk composition looks the same, the physical properties are the same - BUT sometimes, a small amount of additive can have a big difference. Just saying - use at your own risk :)
