options on sst oil change???
sorry for the double post but whos seen this before???
http://www.ebay.com.au/itm/1L-Getriebeo ... 687wt_1006
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
- Beeble
yeah heaps of ppl in the USA and europe have used ravenol
people were quite convinced it was the same stuff, then some stories started surfacing about cars not behaving properly on it. who knows if it is coincidence or not!
http://BeebleTune.com
- Beeble
I'm getting hold of one of the aftermarket fluids shortly.
will do a detailed compare and contrast, and see what's what.
Look forward to that !!!! Gazza
Beeble wrote:Im getting hold of one of the aftermarket fluids shortly. will do a detailed compare and contrast, and see whats what.
Hey Adam, interested in this - how are you going to do a comparison?
If anyone has samples of each oil type I can compare viscosities - I work in a polymer lab so have a bunch of viscometers. This is probably pretty important.
Regarding composition, I can't get definitive compositional breakdown (we don't have the GC-MS any more ) but I can do an FTIR on different oils - this will show us if they are wildly different anyway.
I could also do a thermal analysis on it as well.
Combining all this info will show us HOW similar the different oils are. I wont be able to say 'this oil contains x% of blah and y% of meh' but, if two oils are identical, I should be able to show this.
I'd be happy to volunteer a bit of my time for the wider EVO/RA community if it will help us out.
What you all reckon?
- Beeble
Nicholas - done mate
I'll send you a few samples.
And if we have the Motul aswell - i'm going to tip everything you get is the exact same thing
if we can confirm it in a lab then that is all sorts of awesome.
Geoff - what is the price on the Motul? I'm wondering how it compares. approx RRP is fine if you got it cheap you don't have to disclose! PM me if you prefer..
I am looking at fluids from Castrol and Martini.
I have already looked at Pentosin FFL 2 and FFL 4, SSP Gold. And Willall. No need to test any of them
- Beeble
^ of course. got to have the control fluid.
I've got gallons of the stuff, happy to donate 100ml for "the cause"
- Beeble
someone should buy Ravenol to throw it in the mix. I had some but it's gone now, dammit
- Beeble
can your pour a little on a white plate so we can see the colour please?
I'm going to do this too for the others as soon as they rock up
Guessing they will all be a rusty green. but then I wonder if some companies will add a dye to the fluid to try and confuse us all...
RRP on Martini is 165 per 5L tin RRP or something like that. so about the same price as Motul.
Castrol is hard to find but can be found for a bit less.
