*CLOSED* 7" DVD/SAT Nav GB (ROF1703N-1) - DEC'12
yeah atleast you got it working! ill go hook it up and ill take photos and if yous ay its all good ill connect the battery and hope for the best
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
ok well i connected it all up, but i need confirmation that this is all that need to be connected.. and the ribbon cable is connected too.
also ground cable is connected as you can see at the top..
- rokpapaziz
OK, the plugs look fine, but I'm a bit worried about the earth wire.
It's hard to see, but it looks as though you've connected to ground to a screw where the plastic part of the dash is.
You want to contact with a metal on metal connection. A metal bolt that is part of the chassis or body.
Will take a pic of an example to show you later.
If I'm wrong someone please help this guy
- rokpapaziz
