Postby SIX » Fri May 10, 2013 8:42 am
I used the meguires clay bar kit on mine it works well :)
Damir
Postby Damir » Fri May 10, 2013 9:34 am
TrojanHorse wrote:Awesome :/ lol. I was wanting to see about getting another wax for after it cause Ive got meguiars wet look cleaning polish but thats not making the water bead still (might be that it needs clay barring, I dunno) has anyone got any suggestions or recommendations on what they use? I thought the best thing would be a proper pure carnauba wax but the pure wax in a tin from mothers is $40! There is a liquid bottle of the same stuff which is $27 but didnt know if that still wouldnt be great cause of the formula. Interested to hear what others use and the result..
You should use the actual meguires polish, the one you rub in with your hand, that makes the water bead, trust me, i do it on my car, sometimes the panels go perfectly dry
ScootaX
Postby ScootaX » Fri May 10, 2013 11:09 am
1. Pasti dip badges black
2. Washed car
3. Clay bar the car ( awesome everyone should do it)
4. Polished
5. Wax x2
6. Really just a full detail :)
shamoo
Postby shamoo » Fri May 10, 2013 11:40 am
Erin you need to go see RyanMK. I need to get him to finish off my car. I love how smoothe my door feels!
RyanMK
Postby RyanMK » Fri May 10, 2013 12:21 pm
I've got a few different waxes and sealants that I'm happy to let you try out.
shamoo wrote:Erin you need to go see RyanMK. I need to get him to finish off my car. I love how smoothe my door feels!
Hopefully sometime next week if you're free? I have a ton of assignments which are due this week, but I should have a short free window after that.
RyanMK
eshanes
Postby eshanes » Fri May 10, 2013 1:22 pm
SIX420 wrote:[quote:77fc0976ce=eshanes]I got a little bored and had some spare LED strips, so now I have floor illumination! First time Ive deviated from the red/black theme so Im not sure if itll last or will eventually be swapped out for red LEDs. [img:97230ab47c]http://www.clubcj.net/img/images/20130509175312_IMG_20130509_170434.jpg[/img:97230ab47c][/quote:77fc0976ce] how hard was that to do ?
I wouldn't say it was difficult, it was quite time consuming though as I'd consider myself an electrical novice so I spent a lot of time triple checking things. I tapped into a fuse behind the glovebox and there's a hole at the back of each footwell so I just fed the wires through there. It's only on a switch, I didn't even try to get into the dome light circuit. It's my first lighting mod and I get the feeling there'll be more!
byzon3
Postby byzon3 » Fri May 10, 2013 1:36 pm
Received uk \'X\' badge to put next to the wording evolution on boot and received \'FQ\' badge to replace MR badge
woollzz
Postby woollzz » Fri May 10, 2013 1:39 pm
I know my ralliart will run a little lean with this on, but is it going to be a big deal if I have this on for a couple of weeks before getting a tune at the end of may??
Postby lancerdarryl » Fri May 10, 2013 2:30 pm
byzon3 wrote:Received uk 'X' badge to put next to the wording evolution on boot and received 'FQ' badge to replace MR badge
Picture when you get it on!ImageImage
I did my "X" badge on the cheap........
debonaire
Postby debonaire » Fri May 10, 2013 2:38 pm
Just don't drive hard Michael, you'll be fine.
Craker
Postby Craker » Fri May 10, 2013 3:41 pm
Got my car tuned by mrt using ecutek software. Goes so much harder now, like a different car.
enkei sc 22 wheels
