*CLOSED* 7" DVD/SAT Nav GB (ROF1703N-1) - DEC'12
For all ClubCJ Members.
robert43
Postby robert43 » Thu Jan 03, 2013 3:15 pm
Why do you say + rather than - on the battery? I would like to know your reason?
bunnishiwa
Postby bunnishiwa » Thu Jan 03, 2013 3:24 pm
Agreed re battery terminal. Every install i've ever done has been with the negative disconnected
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
robert43
Postby robert43 » Thu Jan 03, 2013 8:11 pm
Hi the reason why I asked is because I seen people do the + 1st & the spanner has hit the body of the car which is the - & been very intresting .LOL
dannyboi
Postby dannyboi » Thu Jan 03, 2013 8:20 pm
I think they've got the red cover over the positive terminal on my stock battery, so they've intentionally made it harder to remove the positive terminal.
robert43
Postby robert43 » Thu Jan 03, 2013 9:27 pm
dannyboi wrote:I think theyve got the red cover over the positive terminal on my stock battery, so theyve intentionally made it harder to remove the positive terminal.
More like so you know that goes on the + also most battries have a red & black ring on the terminals
RAwannabe
Postby RAwannabe » Thu Jan 03, 2013 10:20 pm
Crift wrote:Whats the new maps like compared to the old ones? Apart from the Aussie voice?
I wonder why the car icon is removed from the map visual and now It's only using a tiny tiny dot representing your car?
I can't tell where my car exactly with the dot and confusing where you suppose to turn, and there is no option to add bigger icon.
denzza
Postby denzza » Fri Jan 04, 2013 3:15 am
I've checked everything:(
I finally found the fuse that blew that controls all the interior lights..
But can some be kind enough and give me step by step instructions how to install. I keep blowing fuses lol
Thanks guys
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
cammag5
Postby cammag5 » Fri Jan 04, 2013 10:20 am
Just so you guys know the can bus allows the head unit to interpret everything the car does with out having to individually wire each connection to each device/switch on the car. So you need the can bus for the unit to recognise when you turn the head lights on or off, when the hand brake is on or off and when the car is in reverse etc. The supplier has give us a bum steer the can bus does literally nothing for the audio, all the audio connections are through the main plug to the back of the unit so it doesnt matter if you have the rockford or not because the can bus does nothing for the rockford.
So in summary EVERYONE needs the canbus and this head unit is NOT compatible with the rockford system.
