*CLOSED* 7" DVD/SAT Nav GB (ROF1703N-1) - DEC'12
For all ClubCJ Members.
rokpapaziz
Postby rokpapaziz » Sun Dec 30, 2012 2:24 pm
Has anyone tried to set a destination with the Navigation? Everytime I try to use it it comes up with a missing file error
chukatsung
Postby chukatsung » Sun Dec 30, 2012 2:46 pm
Change the map skin to the autumn one mentioned before
Error should go away
As for the reinstall, did it again and all the clips are in where they should be
Still a bit wavey on middle, top of the head unit.
I think that's meant to be that way? Or it is just me?
I make vinyl stickers!
PM me for details
Or Click here to visit my Facebook page
rokpapaziz
Postby rokpapaziz » Sun Dec 30, 2012 3:07 pm
Thanks Dennis that worked a treat :)
Mine is the same right at the top in the centre. a little bump
chukatsung
Postby chukatsung » Sun Dec 30, 2012 4:12 pm
rokpapaziz wrote:Thanks Dennis that worked a treat :) Mine is the same right at the top in the centre. a little bump
I guess that's normal then haha
Might try yo use a heat gun of some sort to push the dash down a bit =]
PM me for details
Dire
Postby Dire » Sun Dec 30, 2012 5:11 pm
Okay I fixed my navigation..
Either the car needs to be running, not just powered, or my system needed restarting after I put the SD card in properly (was getting the same clipping problem, just had to go deeper :P).
Anyway it works now.
I don't have an old ipod or anything apple to use for music :( so basically I'm stuck with CDs... :? plus if I use 'real' CDs then it won't know the file names... I'm just going to end up with a heap of folders with 'Track 1 Track 2' etc unless I burn everything...
Postby The X » Sun Dec 30, 2012 5:31 pm
Dire wrote:Only time theres anything else is when I have a USB drive connected. On that note, Ive found the only way I can play music off a USB stick is in the console music player (which sucks), and it only plays through the front speakers :? normal radio and CDs dont have that problem... The USB option in the main menu seems to just search for video files, which I havent tried yet. Kinda seems like the only way to correctly play music or copy music onto it is with CDs
Erm... how is your USB stick formatted? I suspect being the unit is a WinCE 6.0 based device you may have to unsure your USB is formatted using the FAT32 file system type and not NTFS.... just a thought.
chukatsung
Postby chukatsung » Sun Dec 30, 2012 6:14 pm
Crift wrote:also the wave issue. honestly the headunit ive installed thus far havent had too much of a wave (<1mm gap) with all sides being <1mm gap with no ridges, everything is flush!
For my HU, everything is flush, just the top middle have a small gap and that made it a bit obvious, but cant complain for the money spent =]
PM me for details
chukatsung
Postby chukatsung » Sun Dec 30, 2012 11:17 pm
I have a question,
How do you wire the TV to have that working?
Everything else work besides that
Do I need an antenna of some sort? Which wire is it for the TV?
PM me for details
