Did you know...?
mitsfan
aussie027 wrote:Mitsfan wrote--Did you know ...
You can significantly reduce interior road noise by applying a good quality moisturizing tyre paint to the inward-facing and outward-facing walls of your tyres?
Mate never heard of this before, are you serious???
If so can you give us all a paint brand, name, and cost for this???
The road noise from these Advan tyres on rough bitumen is terrible and short of pulling the car interior apart to fit Dynamat everywhere or getting new tyres this would be a great alternative if it works. How it would work I dont really understand as I didnt think noise is coming thru the sidewalls but from the contact patch of the tread.
Thanks.
Everyone was probably checking to see if my post was on 1st April - but yes, I am serious.
I used Zaino Perfect Tire Gloss, on the wheels and also on all the rubber seals around the doors and boot/hatch (and also on the rubber around the engine bay touching the bonnet). This is actually a clear product, not a black paint, but the tyres come up looking very nice and black.
The extent of the reduction in sound will depend upon:
- how dry and hard your rubber is to start with.
- how many coats of moisturizer you apply, how liberally, and how often.
Rough bitumen road noise is still too high with the stock tyres in interior noise, but I did notice a reduction and change (lowering in frequency) so I thought that others might like to know about this in case they want to try it themselves. (I would expect careful tyre selection to provide a more dramatic improvement, and if this is done when your tyres first need replacing then this need not involve much if any additional expense either.),
The additional noise suppression is really a side benefit to moisturizing all your rubber, but given the degree of internal noise being an issue with CJ Lancers, owners tend to be interested in anything that helps, especially when it does not involve much cost, installation, or additional weight.
Tarquin wrote:tadz0rz wrote:I knew about the car speeding up but didnt know abouut the cruise set button slowing the car down. Interesting!
NOTE: It does not decelerate the car... It just coasts.... You still need the brake...
I live on the cruise buttons... love it for good flowing traffic doing 60 & 70km/h too....
Strange then, The car actually slows down on mine.
ofey wrote:Tarquin wrote:tadz0rz wrote:I knew about the car speeding up but didnt know abouut the cruise set button slowing the car down. Interesting!
Yes ofey, mine slows down too. but Like Tarquin said, it only Coasts. The same as just lifting your foot off the pedal. It doens't actually brake the car as such.
- JazzyB
Difference between RA and VRX I would think would be that VRX has a 2.4l and RA has 2.0l - even tho it's turbo - it's still a 2.0...
Would seem that the 2.0 engine can be set to cruise as low as 40kph but the 2.4 needs a bit more??
AND:
The roadnoise thing.... works a bit like this....
if u have a hard ruler overhang a table and u flick it, it makes that vibratey sound - this is because it is HARD and the vibrations (note - all sound is simply a vibration that has entered your ear) will travel along it without being hindered...
in contrast... if u have, say, a banana skin overhang the edge and u flick it, there will be little to no noise... This is because the banana skin DOESN'T keep vibrating and producing a noise, it is soft and absorbs or 'dampens' the initial flick, and doesn't keep vibrating.
Softening ur tyre-walls and seals has a similar effect. The sound is literally a vibration from the road, thru ur tyres, axles etc. etc. until it reaches ur ears. if you soften the tyre WALLS, this will in turn 'dampen' that vibrations, and doing ur seals will stop the vibrations from getting to your doors and windows or, at least dampen them as well.
This is also why lower profile tyres have more road noise... there are MORE hard, vibration transmitting surfaces so the vibrations/sounds don't have a chance to be silenced out by traveling through a thick, juicy banana skin... oh! i mean tyre
AND:
mitsfan
JazzyB,
Yes you are right about the theory, the interesting part is how much difference in road noise moisturizing rubber tyre walls and door seals can actually make. It is not something you find people discussing much online. Have you, or anyone else noticed any significant noise reduction from this?
- tadz0rz
When i sound deadened my wheel wells, i just used this K&N under body body spray on deadener. Improved it quite a bit for $40, still there is road noise of course but since i did that and got new tires fitted to the car, its now slightly less noisy than it was when i had the stock 16" tires on. And now i have 18"
JazzyB wrote:Difference between RA and VRX I would think would be that VRX has a 2.4l and RA has 2.0l - even tho it's turbo - it's still a 2.0...
My VRX is a 2.0.
And I can't set under 50. But I can coast it to 40 and still have it lock on.
