All Lighting Questions Here!
- The X
FizyMo wrote:I also install these led light on the side of my doors like this
I've been looking at getting some strip lighting for the doors, more as a safety/asthetics thing. How did you wire them up, to the door switch or some other harness...? Is the door switch just a relay or can you pull power from it?
Hey pete, i wired these up by tapping with the dome lights and put a switch between it, so everytime when the door opens the LED strips light will come on..
I can also switch them off by putting a switch between it.. ill grab a pic for you of the switch brb lol
Here it is Pete
So basically the LED is getting power from the dome light itself, so if i turn the custom switch off, the dome light still works but the LED will not.
Hope this helps
Its easy to do, but takes alot of stripping the side panels and such, cause i did it on all 4 doors
Here it is Pete
Hope this helps
".FizyMo."
- The X
FizyMo wrote:So basically the LED is getting power from the dome light itself, so if i turn the custom switch off, the dome light still works but the LED will not.
Hope this helps
So you had to run 4 different cables from the dome light down each B-pillar then to the door hinges? Sounds quite involved.... LOL
Must be an easier way to tap the relay behind the dash assembly where the dome is fed power.
- The X
FizyMo wrote:ahaha yea mayb there is... but its working n no fire in my car ahaha so its ok
Yeah the "dclub fog/smoke" feature, is not something I want, tho it would look sick with my blue LEDs in the car. hahahaha
