SST Fluid comparison - Results
BST50N
Postby BST50N » Tue Feb 25, 2014 3:21 pm
gman90 wrote:I sent about as much as last time hope that is enough Gary
Ok lets hope so! It's the viscosity readings that I need a bit for.
gman90
Postby gman90 » Tue Feb 25, 2014 9:06 pm
Hi Nic will send more if you do need it . Gary :oops:
BST50N
Postby BST50N » Tue Feb 25, 2014 9:09 pm
gman90 wrote:Hi Nic will send more if you do need it . Gary :oops:
No worries mate, we'll see how we go
gman90
Postby gman90 » Sat Mar 01, 2014 6:51 pm
Hi Nic you should have got 2nd sample by now ????? Thz gary
BST50N
Postby BST50N » Mon Mar 03, 2014 12:18 pm
To Gary and Beeble - what date did you guys send the samples? You sent to same address as last time I'm assuming? I thought they'd have turned up by now?
BST50N
Postby BST50N » Mon Mar 03, 2014 1:21 pm
Ford fluid received from Gary 8)
R4LLI4RT
Postby R4LLI4RT » Mon Mar 03, 2014 1:25 pm
cant wait to see more results of the oem ford vs oem mmc
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
gman90
Postby gman90 » Mon Mar 03, 2014 1:39 pm
Hi Nic .All Good Thanks for all your time in doing these tests :D Gary
gman90
chris
Postby chris » Thu Mar 13, 2014 3:19 pm
Any more results?
Beeble
Postby Beeble » Thu Mar 13, 2014 3:43 pm
I have sent some Castrol Transmax Dual up yesterday... Nick should hopefully get it today or tomorrow.
Very keen to see how that compares against the OEM fluid. Many people say it is the same thing :)
despite all these results thus far I'm still using, and being asked for by most people, the OEM stuff.
We'll see if that changes!
http://BeebleTune.com
R4LLI4RT
Postby R4LLI4RT » Fri Mar 14, 2014 8:32 am
Transmax will be interesting to see?
Nick any news???
DBA Extreme Pads
Tein S Tech Springs
BST50N
Postby BST50N » Tue Mar 18, 2014 9:23 pm
Flat out at the moment guys. Got the Transmax in. According to the FTIR
DiaQueen = Ford = Transmax
This is only one test however. I still need to do viscosity, and density to see if those are also the same.
Will get a comparison graph up of the Transmax FTIR when I get the chance - may not be for a while though as work is hectic for the next few weeks.
Speedie
Postby Speedie » Tue Mar 18, 2014 10:27 pm
Does anyone have some of the Willall to test?
R4LLI4RT
Postby R4LLI4RT » Wed Mar 19, 2014 7:13 am
Nick!! good to see your alive buddy!
looks like Adams predictions maybe correct at this stage
good for all of us as i think the transmax is the cheapest, but is it easy to get a hold of here?
DBA Extreme Pads
Tein S Tech Springs
