copy of Accolade's Rear lip/diffuser - Bodykits Kingdom
- chunky9
wow what on earth is going on with the centre
but it does look sexy indeed
My progress thread: http://clubcj.net/viewtopic.php?t=13443
RAwannabe wrote:according to your last photo, push in the shark fin bit then you will know where to drill holes to pull it up.
Ok thanks man will have a look at it and apparently my number plate will fit once the lip is on, it may hang over slightly
chunky9 wrote:wow what on earth is going on with the centre but it does look sexy indeed
Yeh I know it's a bit odd, sure does
sleepy wrote:Looking awesome Ben! Considering getting either this or Ill try to push my luck and source a Ralliart rear bar... (any Ralliart owner want to lend their VIN?) Only problem I have with this is where the reverse sensors sit on mine, which is just below the license plate.
Cheers mate, It will look better once its on and the xforce exhaust is installed. Yeh i was considering the ralliart rear, until i found out the price just to get the bumper with no painting or fitting so thats why i went with this lip. Also i would have had to move or buy new reverse sensors.
gus0068 wrote:My mrs has the Lancer Platinum in white this could be the go
It finishes the rear of the lancer off nicely Chris. The stock rear in my opinion just does not do it for me.
DORA_ANNE wrote:How is the fitment going Ben ?
Its not actually on the car yet Doreen but from the photos when i trail fitted it, Its pretty good. Will post up more pics when the lip is on so u can get a better idea.
copy of Accolade's Rear lip/diffuser **UPDATE**
Old and new!
DORA_ANNE wrote:Looking Good BenDid they have to do anything to your exhaust to make it fit better ? And was it the panel beaters shop who installed & painted ?
Thanks Doreen. Yea my exhaust place I go to had to cut off the exhaust pipe connecting to the muffler and fuse it back together with the tip angling down. I'm planning on getting the Xforce axle back so it is just a temp fix. If you have no tip or at least a small tip on the exhaust end it should fit fine, without modifying. Mine is 3.5'' so it was touching the bumper pretty easily.
Yea I got the lip painted and fitted at DT panels in Springvale for $400
