Postby LZY_EYE » Mon Jul 16, 2012 6:25 pm
I would strongly suggest something more substantial than the double sided tape. Once you wash the car a few times, and it rains there is a good chance it could come away.
BZC-45S
Postby BZC-45S » Mon Jul 16, 2012 6:28 pm
Sold my old iphone 3gs to a friend last night, so I could afford (barely) 2 front tyres. The old ones were literally bald around the outside edge, stock Advan A10A's that lasted barely 21,000kms.
I bought Kumho KU31s in 215/45/18, $180/ea. Planning to replace the rears next month, and do an alignment then (and get then from a ClubCJ sponsor at $11 less each - lol researching after buying). Meanwhile, these feel great so far. Definitely notice less noise gently putting around Sydney's pothole riddled roads.
alterego13
Postby alterego13 » Mon Jul 16, 2012 6:32 pm
Installed the RA intake snorkel yesterday
What a job!!! Phewww ;)
Now to find a longer christmas tree clip...its held by just 1 clip at the moment
Stripler
Postby Stripler » Thu Jul 19, 2012 12:45 pm
Got some 18" fin wheels. Previous owner had some garish looking rims on there so went for a clean oem look this time. Loving it
tencents
Postby tencents » Sat Jul 21, 2012 10:06 am
boostpill installed.. finally... its alot easier to get the hose off if u don't use brute force to pull.. gently push and it comes off.. geez.. *doh*
- GST basemap
- AMS boostpill
- Evo X BPV
- UR UICP
Postby SAM-24A » Sat Jul 21, 2012 10:09 am
Yep .... I generally find that Pushing is better than Pulling ..... :roll:
Sam .... *doh*
bunnishiwa
Postby bunnishiwa » Sat Jul 21, 2012 11:36 am
tencents wrote:boostpill installed.. finally... its alot easier to get the hose off if u dont use brute force to pull.. gently push and it comes off.. geez.. *doh*
Cool - thanks for the heads up. Just ordered mine off UR ($US$18 delivered 8) ) so now know what to do :D
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
cjdee
Postby cjdee » Sat Jul 21, 2012 1:34 pm
I had my 1500 km check up done. Now to remove those MIVEC badges
Tweak
Postby Tweak » Sat Jul 21, 2012 1:41 pm
Fitted 8kg Springs to my rear coilovers. Yet to fit the front 10kg springs 2morow
Postby SAM-24A » Sat Jul 21, 2012 2:18 pm
*bump* to this 283 page .... somethings not working properly again .... *confused*
Postby SAM-24A » Sat Jul 21, 2012 2:19 pm
@ Cam
Why would you want to fit Harder Springs to your Coilovers ....
that's only going to return a Firmer/Jarring level of Ride Comfort for Road use .... *confused*
If your wanting to Improve the Handling Characteristics .... then simply Adjust the Compression / Rebound Valving ... 1-32 increments.
Merlinised MIVEC -AspiRe 2.4L
Postby lancerdarryl » Sat Jul 21, 2012 2:27 pm
Spring rates that high for a road car are going to make your fillings fall out and the car unpleasant to drive.The stiffest spring rate I have ever used on my rally car was 180lb (slightly less than 4kg) and it was way too hard.
Postby SAM-24A » Sat Jul 21, 2012 2:36 pm
8kg & 10kg Spring Rates are nearing the rates that Light Drifters use.
Perhaps that's Cam's Intention ....
Postby ofey » Sat Jul 21, 2012 2:40 pm
I just tried driving mine (BCs BR Type) on the HARDEST setting on some sub-urban/urban roads. These come 4kg and 6kg
UNBEARABLE
Unless you're tracking the car FULL TIME, I don't suggest you go 8 and 10.
Users browsing this forum: Google [Bot] and 26 guests
