*CLOSED* Evo Rep Prts CCJ GB SEP'11
For all ClubCJ Members.
SEB15
Postby SEB15 » Mon Jan 23, 2012 3:16 pm
EVO X bumper bar Progress!
SEB15
Postby SEB15 » Mon Jan 23, 2012 3:21 pm
Must say is not a perfect fitt Under the car is out of aligment, the wholes dosen't match the plastic cover at all, i catch it up with screws, plastic cover on top (engine bay) is not sitting propley on the bar, fog lights are illegal ( too bright, they light up nearly like high beams)
Postby bd-850 » Mon Jan 23, 2012 4:04 pm
umm im not sure if you know, but did you know your garage is built upside down :P
But it looks good (part from that close up pic)
13EZY
Postby 13EZY » Mon Jan 23, 2012 4:09 pm
Looks good seb
Ride Of The Month June 2011
tadz0rz
Postby tadz0rz » Mon Jan 23, 2012 6:07 pm
Whats the plans for the old RA bar.... :)
Postby bd-850 » Mon Jan 23, 2012 6:08 pm
jump on it Tadz
tadz0rz
Postby tadz0rz » Mon Jan 23, 2012 6:12 pm
Im considering it since one of my front pods is cracked. Glued it back up and everything however ill need to get the splash guard and foggies to go along with it unless seb can provide them..? Cant remember if the evo front bars included the foggies...
Also seb, probably half the reason why the front bar holes underneith do not suite is because the RA splash tray is different to the NA lancer splash guard. However we will soon find out if im correct when someone puts it on their NA...
Fitter
Club Vendor
Club Vendor
Postby Fitter » Mon Jan 23, 2012 6:25 pm
i will be test fitting on my NA on thursday :) didnt get around to it on weekend :(
CLUB CJ CAR AUDIO VENDOR
2013 WORLD TITLE
2012 QLD State Champion
2008 Australian Champion
SEB15
Postby SEB15 » Mon Jan 23, 2012 6:34 pm
bd-850 wrote:umm im not sure if you know, but did you know your garage is built upside down :P But it looks good (part from that close up pic)
On close up pic i just to put the bar on to see how it looks!
and lol for the garage!
tadz0rz wrote:Whats the plans for the old RA bar.... :)
Not selling the RA bar from 2 reasons:
1. I'm NOT 100% happy with the new bar
2. The new bar seems to be pretty fragile
Sorry Tadz0rz!
13EZY wrote:Looks good seb
Thanks! :)
Postby bd-850 » Mon Jan 23, 2012 6:36 pm
SEB15 wrote:[quote:733d5b2dd1=bd-850]umm im not sure if you know, but did you know your garage is built upside down :P But it looks good (part from that close up pic)[/quote:733d5b2dd1] On close up pic i just to put the bar on to see how it looks! and lol for the garage!
well thats ok then, so Yes the bar looks good
tadz0rz
Postby tadz0rz » Mon Jan 23, 2012 6:59 pm
Dang :(
Fitter
Club Vendor
Club Vendor
Postby Fitter » Thu Jan 26, 2012 2:05 pm
bar is on but there is a 1" gap (25mm) between the bonnet when fully closed and the top of the bar :(
tow point cover has no clips and i will have to glue it in place or just have a hole in the front of my bar :(
black plastic covers doesnt sit down properly, will need to trim a little bit of plastic out where you put your hand to open bonnet latch :(
the rest of it fits fine :)
2013 WORLD TITLE
Postby bd-850 » Thu Jan 26, 2012 2:20 pm
so the way i read it, part from not fitting its good? :P
Fitter
Club Vendor
Club Vendor
Postby Fitter » Thu Jan 26, 2012 2:25 pm
just had another look at it on the car, i have taken the rubber strip off the OEM bar and put that in place (sat there) and realised i have to drill the holes for the clips, the metal brakets that secure the OEM bar to the front bracing needs to be removed from OEM bar and attached to new bar - rivet holes need to be drilled, the big white clips need to be taken off the OEM bar and holes drilled in new bar and have them rivetted to it (they clip in under the headlights.
im thinking that when the metal bracket goes on it will lift the top of the new bar and push it out a little so as to reduce that 1" gap
2013 WORLD TITLE
SEB15
Postby SEB15 » Thu Jan 26, 2012 5:52 pm
Yes you ill find out the plastic cover not fitt propley and the rubber strip as well, aslo the black plastic from the wheel arch
Users browsing this forum: No registered users and 78 guests
