timmo91
Postby timmo91 » Sat Apr 14, 2012 6:43 pm
Dazz4C wrote:Installed tail lights. Though the drivers side doesnt always turn on (same with the driver side LED parker...). Issue with the parker has always been there. Perhaps crappy wiring... [img:0f878f90e8]http://i.imgur.com/5USLw.jpg[/img:0f878f90e8] Drivers side also flickers/dims very lowly when the light have turned off for about 30 seconds to 2 minutes (maybe I might need to put a resistor in there somewhere.)
This excact thing happened to me :( Just need to get a new set of parkers... should fix the problem.
Dazz4C
Postby Dazz4C » Sat Apr 14, 2012 6:51 pm
timmo91 wrote:This excact thing happened to me :( Just need to get a new set of parkers... should fix the problem.
I tried pulling out the driver's side parker - seems to be the same. I'll try pulling out both and see what happens.
EDIT: Pulled out and tested. Same thing happens. Put in some other LED's in the parkers, and it still happens.
This happens in sync with the rear LED tail lights, so it's probably the wiring.
timmo91
Postby timmo91 » Sat Apr 14, 2012 7:03 pm
Dazz4C wrote:[quote:8f1f0cf674=timmo91]This excact thing happened to me :( Just need to get a new set of parkers... should fix the problem.[/quote:8f1f0cf674] I tried pulling out the drivers side parker - seems to be the same. Ill try pulling out both and see what happens.
Oh ok :/ strange...
Bags
Postby Bags » Sat Apr 14, 2012 7:08 pm
SAM-24A wrote:Hey Ben ..... read this thread: BC Coilovers Sam .... *thumb*
Thanks Sam, I have had a read there and think that is the way I will go. From the way I read that SKU B-19RA will suit MY11 SX yeah? That is what I interpreted anyway but I am VERY tired!
dragansj
Postby dragansj » Mon Apr 16, 2012 12:16 pm
Installed 4 replacement speakers and sound deadened the doors ..... much bettera now.
timmo91
Postby timmo91 » Tue Apr 17, 2012 11:08 pm
Wow those wheels look killer Ryan! Well done :D
T-All3NT
Postby T-All3NT » Tue Apr 17, 2012 11:20 pm
fixed my trunk light cause they fell out of the zipties idk how but its fixed now
timmo91
Postby timmo91 » Tue Apr 17, 2012 11:22 pm
T-All3NT wrote:fixed my trunk light cause they fell out of the zipties idk how but its fixed now
Yeahh mine is slowly peeling of :P Gotta try zip tie it down..
T-All3NT
Postby T-All3NT » Tue Apr 17, 2012 11:24 pm
timmo91 wrote: Yeahh mine is slowly peeling of :P Gotta try zip tie it down..
its sort of annoying to get it down, cause none of the holes in the trunk line up lol, i found the easiest way is to loosely do up the zips and then slide the leds through and tighten
timmo91
Postby timmo91 » Tue Apr 17, 2012 11:26 pm
T-All3NT wrote:[quote:1e7c30e9e5=timmo91] Yeahh mine is slowly peeling of :P Gotta try zip tie it down..[/quote:1e7c30e9e5] its sort of annoying to get it down, cause none of the holes in the trunk line up lol, i found the easiest way is to loosely do up the zips and then slide the leds through and tighten
Ah yeah, will give it a go when I get some time.
Leez
Postby Leez » Wed Apr 18, 2012 7:25 pm
Someone else installed a new weight saving mod for me :(
F***ING lowlifes.
Postby bd-850 » Wed Apr 18, 2012 7:27 pm
oh that fooking sucks
Dirtee
Postby Dirtee » Wed Apr 18, 2012 7:29 pm
aw what dirt bags! :(
2010 Lancer Es - My Ride
Wanna be customiser!!
ACT Rep 2012
CJLancerInstalls - How-To's!
tencents
Postby tencents » Wed Apr 18, 2012 7:30 pm
fark....... do you park ur car on the streets? Hope the same thing happens to those punks balls.
- GST basemap
- AMS boostpill
- Evo X BPV
- UR UICP
