JaCe
Postby JaCe » Thu May 20, 2010 11:38 pm
I personally just use my series 60 Nokia (N97 Mini, but had it on my E71 too) with Joikuspot to create a wifi hotspot in my car.
Big_Lucas
Postby Big_Lucas » Fri May 21, 2010 5:27 pm
Installed my UR Braces.. Much Better
tadz0rz
Postby tadz0rz » Fri May 21, 2010 5:32 pm
Video of my carputer being tested out
http://www.youtube.com/watch?v=9cjrNfcptXc
Red EVOX
Postby Red EVOX » Fri May 21, 2010 8:19 pm
This morning i fitted the cat back section of my Turboback exhaust (still have the 02 housing, engine pipe and cat pipe to fit)
robnkel
Postby robnkel » Fri May 21, 2010 11:16 pm
Had it in for its 1500k service, if you can call it that.
Anyhow they fixed the handbrake.
And I havent found any dents or scratches which is a bonus.
2010 Lancer Activ
Skorps
Postby Skorps » Sat May 22, 2010 1:10 am
My car had King springs fitted which in turn lowered my car with nice side profile as you can see:
2010 Ford Focus XR5 LV Mk ll
tadz0rz
Postby tadz0rz » Sat May 22, 2010 8:39 am
Had my 30,000km service + Gearbox oil change yesterday. Heaps smoother now :D
LukeD
Postby LukeD » Sun May 23, 2010 12:33 pm
Took some photos after cleaning it.
Also order some custom plates VRX010
The best diffuser for the rear is a talon one correct. If so how long does it normally take for arrival to Adelaide? And what is the general price for one for a 2010 VRX.
Reason im asking is i need to get an exhaust and the double diffuser with the twin exhaust has always looked best to me.
Advice?
bobcrusader
Postby bobcrusader » Sun May 23, 2010 4:16 pm
I removed a pair of pliers (mine) that had worked their way to the floor pan and were half sticking out and dragging on the ground. Such a relief that the nasty grinding/ticking noise was not the SST!
Since it wasn't the SST, I went and loaded my own custom map and took it for a drive - no CEL or Limp mode or pinging. But certainly a little quicker, and hopefully more economical :)
- 2009 Lancer Ralliart
- Boostpill + Tune
- Upgraded intercooler + pipes
- Turbo XS Catback
- Drift BoV
- Blitz Air Filter
Postby aspir3 » Sun May 23, 2010 6:32 pm
LukeD wrote:The best diffuser for the rear is a talon one correct. If so how long does it normally take for arrival to Adelaide? And what is the general price for one for a 2010 VRX.
Advice?
On Saturday you can talk and see Blackbetty's Talon rear diffuser. Yes it is good for twin exhaust pipes.
I have the OEM which only has the single pipe.
You can see the two and decide what you like the best!
Rob_RA
Postby Rob_RA » Sun May 23, 2010 7:57 pm
Fitted the rest of my UR bars (with some help) and added some bling to the front :wink:
SIR-VRX
Postby SIR-VRX » Sun May 23, 2010 8:14 pm
Yesterday:
Swapped my black window strips with sleeper's chrome :) Thanks Steve!
Today:
Finally got around to putting the second fender bar on :)
UltraRacing Sticker:
Red EVOX
Postby Red EVOX » Sun May 23, 2010 8:27 pm
I ended up fitting the rest of my turbo back exhaust lastnight and then gave it a quick AFR check on the dyno this morning (not the normal dyno that i use) to make sure all was ok until i it gets tuned in 2 weeks.
LukeD
Postby LukeD » Sun May 23, 2010 10:09 pm
SIR-VRX wrote:Yesterday:
Those strips would look nice on my VRX, where did ya get those one's
SIR-VRX
Postby SIR-VRX » Sun May 23, 2010 10:15 pm
I swapped my stock Black ones with the Chrome ones off fellow member sleeper's Ralliart.
