- squala
- Post Monster
bez3rk wrote:installed chrome vinyl today 20 bucks off ebay turned out ok [img:357828c8a6]http://www.clubcj.net/img/images/20120305202016_chromestrip.jpg[/img:357828c8a6][/img]
That's not bad at all. It's good to know another chrome lover out there.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
Got a 4 wheel alignment. Hoping it'll save my tyres from further uneven wear. The before readings were expectedly terrible: +.8mm one side, -.2mm the other for front toe.
Backstory: 3 of my 4 tyres have the outside edges scrubbed pretty bad. With less than 14,000kms on the clock, the tyres don't seem like they'll make it past 20,000kms.
After I spent the weekend busting my butt to clean and wax my car... I parked it at work yesterday and a huge truck came along, parked across the road, then cut down and woodchipped an entire bloody giant eucalyptus tree; covering my entire car in dust and wood
When I got home I sprayed it down with the hose... and all the water then beaded and dried into water spots all over it.
FML.
FML.
4 x NGK Iridium Spark Plugs - FR6EI-11 $11.50 each
1 x Spark Plug Socket 16mm $5
1 x Wax/Grease 1L Remover $13
1 x 3M Plastic Primer $19
1 x 3M Engine Enamel 300deg - RED $16
(All from SuperCheap Nerang QLD)
1 x SandPaper & block (n/a)
- Changed my spark plugs (Do I have a engine problem??)
- Sanded & plastic primed Spark Plug & Engine Covers for RED paint (special logo design comming soon)
- Cut opening bigger like "How To Improve Airflow Video" waitting on Mesh.
http://www.clubcj.net/img/images/201203 ... AG0047.jpg[/img]
Unknowen kms with these in & all have Burn marks on plug insulator.
NGK say "The high voltage applied to the spark gap is also applied to the area between the centre electrode and the metal shell, causing an insulation breakdown of the air at the gap between the insulator and the metal shell. The phenomena is called a corona discharge."TextText
chudders wrote:decent wash of the car and of course it rains later... mud everywhere!
We must live in opposite world - I took my car out for a run on the weekend to Warragamba Dam, hoping to see the dam overflow, etc. Ended up travelling on a section of unpaved road. Splattered mud everywhere on the car.
Today, it rained pretty heavily while I was parked at work - open space carpark - free car wash.
Users browsing this forum: No registered users and 48 guests
