Deano: LED DRL's
Deano1964
Postby Deano1964 » Tue Jul 06, 2010 12:35 pm
Basically they come pre wired.
They come pre wired on both sides of the strip so that u can split them in half and it still be wired.
All you need to do is power/ground.
I spliced mine into parking lights so that if i forget to turn the switch off and i turn of the car, they go off.
In my first post in this thread i used 2x "6inch"
and then i changed them to 2x "1 foot"
Deano1964
Postby Deano1964 » Tue Jul 06, 2010 12:38 pm
Blakey wrote:
Deano1964 wrote:They aren't blue at all...the photos are quite deceiving.
The second photo has a lot of glare cos it was taken with a iphone in bad light.
They are a cool white, Same colour as around a 6k xenon, of course not as bright but that white colour.
a 6000K xenon is blue...
BR14AN
Postby BR14AN » Tue Jul 06, 2010 3:18 pm
Hey Deano,
This looks flash! Really like it.
Quick question, how flexibe is the led strip? If you try and mold it into a shape will it snap?
Thanks
Aspired
Postby Aspired » Fri Jul 09, 2010 5:51 pm
BR14AN wrote:Hey Deano,
Thanks
Looks pretty flexible
Deano1964
Postby Deano1964 » Fri Jul 09, 2010 6:00 pm
Thanks
Very flexible, same sorta flex as a normal led strip.
The only problem i can see is if u want to flex it 90degrees...
BR14AN
Postby BR14AN » Fri Jul 09, 2010 6:38 pm
I was hoping to run it along the headlight, and it needs to be fairly flexible for that :P
Deano1964
Postby Deano1964 » Fri Jul 09, 2010 6:40 pm
BR14AN wrote:I was hoping to run it along the headlight, and it needs to be fairly flexible for that :P
will be more than flexible for that
Dire
Postby Dire » Fri Jul 16, 2010 3:56 pm
I've done the same thing as Deano on my car. Was contemplating other placements but I think 'around the headlights' is too ricey.
Fail photo, but you get the idea.
They're quite visible, I set them a bit too far in so you need to be a few metres away to see them standing up. But it'll do :D
As you can see they're bright enough to significantly light up the ground.
'Side-emitting Headlight Strips' from oznium.com (neutral white).
Oh and the CCFL tubes.
And the parkers (neutral white again). :P
All 10/10 products. Not a single complaint from me. Except the CCFL's should come with 3M tape like the LED's :(
(that little black line on my radiator is electrical tape, I should get that off :P:P)
Dire
Postby Dire » Fri Jul 16, 2010 4:07 pm
13.49US per foot (so I have 2 1ft strips so x2).
We did a WA group buy to save on postage cos we're poor bastards :P
BR14AN
Postby BR14AN » Tue Jul 20, 2010 10:44 pm
Just ordered some 1foot neutral white :)
Aspired
Postby Aspired » Tue Aug 24, 2010 10:52 pm
Mine arrived today :)
BR14AN
Postby BR14AN » Tue Aug 24, 2010 10:54 pm
My copy of Deano's DRL
Aspired
Postby Aspired » Tue Aug 24, 2010 11:10 pm
Did you guys cut off the other end of the wire that is not connected ?
BR14AN
Postby BR14AN » Tue Aug 24, 2010 11:15 pm
Aspired wrote:Did you guys cut off the other end of the wire that is not connected ?
Yeah just snip it off :)
