Black out front grill
Ozie
Postby Ozie » Mon Dec 15, 2008 3:03 pm
dude they are the only screws holding it on..
i have the same car as you....its easy..lol.
Bobcat_GTS
Postby Bobcat_GTS » Mon Dec 15, 2008 3:47 pm
Don't you have to take this panel off before you can get to the clips that hold the grille on?
Ozie
Postby Ozie » Mon Dec 15, 2008 4:22 pm
yes bobcat thats what i was talking about,
i forgot there was more than 4 screws but yeah, this has to come off..
then your able to remove the grill easy.
Bobcat_GTS
Postby Bobcat_GTS » Mon Dec 15, 2008 5:30 pm
I kinda figured that's what you meant, but since I've never attempted to take my grille out I wasn't sure.
There are 6 plastic rivet things. The 2 on the snorkel are screws, but the rest just pop up then you have to push them back down a bit and grab the lower part, not the part that pops up to pull them out.
Ozie
Postby Ozie » Mon Dec 15, 2008 5:32 pm
yeah cheers bro,
simple design how it all come off.
Vmo91
I got no luck
Postby Vmo91 » Wed Dec 17, 2008 11:01 am
the bumper came out with all bubbles and messed up looking, ah
Tutteron
Postby Tutteron » Wed Dec 17, 2008 11:35 am
When I got my vinyl from the sign writters (which I have still not fitted), he said to spay the area where you are going to put the vinyl with a mix of soapy water. In thinking, this is the same as what you do when applying film to windows.
If you heat gently, and I mean gently with a hair drier, this might soften the glue a little so you can squeegie the bubbles out. Don't pierce the bubbles with a pin as it will look crap when it gets wet and will also allow water ingress.
Hopefully the above helps.
Ozie, Maybe you could add this into the "how to's"
Vmo91
Postby Vmo91 » Wed Dec 17, 2008 11:52 am
Thanks i have to try that
Tutteron
Postby Tutteron » Wed Dec 17, 2008 12:35 pm
I was going to edit my note before, but thought best saying it separately.
The reason why he said to use soapy water when applying the vinyl is so you can still slide it around a little and get the bubbles out alot easier as the vinyl has an adhesive backing. The sun will dry the moisture out eventually.
Vmo91
Postby Vmo91 » Wed Dec 17, 2008 12:41 pm
man your awesome ha
i can't wait to try it,
Hoggy
Postby Hoggy » Wed Jan 21, 2009 3:37 pm
Does someone make an aftermarket plastic cover to go on the centre piece as an alternative to Vinyl? If so how do I get my hands on it so I can sent it to get chromed ;)
s21197
Postby s21197 » Wed Jan 21, 2009 3:41 pm
yeah RRM has a middle bumper cap that comes in carbon fiber and I'm pretty sure one comes in fibreglass too...check it out
s21197
Postby s21197 » Wed Jan 21, 2009 3:43 pm
nvrmind only comes in CF...$200
Hoggy
Postby Hoggy » Wed Jan 21, 2009 3:43 pm
s21197 wrote:yeah RRM has a middle bumper cap that comes in carbon fiber and I'm pretty sure one comes in fibreglass too...check it out
Cheers mate
Bandit
Postby Bandit » Wed Jan 21, 2009 4:19 pm
That numberplate relocator looks good as does the CF bumper centre cap.... I need some decent mud flaps.....
ClubCJ's first Sportback
