LED DRLs, a thought, maybe.
SIR-VRX
Postby SIR-VRX » Sat Jan 02, 2010 10:45 pm
hahaha I'm straight ;)
Postby The X » Sat Jan 02, 2010 10:49 pm
tryg wrote:So would the concesus be a straight line (I intended just making a direct line of LEDs through the centreline of the cover splitting the fog), or make an L shape as suggested by VRX_Pete?
Either a L shape on the outer edge (obtuse L) or on the inner edge, (acute L). both would be worthy of looking into....
Straight is so boring. (No pun intended).
Postby The X » Sat Jan 02, 2010 10:50 pm
SIR-VRX wrote:hahaha I'm straight ;)
I could make a nerdyburger glasses joke, but i wear contacts, so I'd be just own goaling myself. :(
tryg
Postby tryg » Sat Jan 02, 2010 10:52 pm
If you were to do the 'L', then it would certainly have to be across top and down centre....
It would only go across to the fog though, unless you just wanted to adapt your standard covers....
Postby The X » Sat Jan 02, 2010 10:58 pm
tryg wrote:If you were to do the 'L', then it would certainly have to be across top and down centre....
True, unless you skip the inch where the ring is and continue down the side until you reach the lower end of the ring.... or go for the alternate design and track the top and then inner edge and stop as it hits the bottom. :roll:
tryg
Postby tryg » Sat Jan 02, 2010 11:47 pm
if you used some high power 5mm LEDs, you could just do the entire perimeter...
Blakey
Postby Blakey » Sun Jan 03, 2010 12:11 am
SIR-VRX wrote:What post? Did you post it correctly?
yep dam sure i did post it caues it was there then i went and did something else came back and it was gone. if you are gonna delete my posts who ever did it, im pretty sure you are meant to tell the person and give them a reason. as it is for every other forum.
drake89
Postby drake89 » Mon Jan 04, 2010 12:08 am
im currently talking to Chris at Concord Customs about integrating DRL LEDs into my foglight surround.
still in the process. lol
tryg
Postby tryg » Mon Jan 04, 2010 12:10 am
Nice drake, let us all know how you get on!
drake89
Postby drake89 » Mon Jan 04, 2010 12:12 am
will do. =)
Postby LZY_EYE » Fri Jan 08, 2010 6:32 pm
SIR-VRX
Postby SIR-VRX » Fri Jan 08, 2010 7:13 pm
Blakey
Postby Blakey » Fri Jan 08, 2010 8:39 pm
they need a defuser on thoes lights of lzy_eye's they look good but they have to much glare. /they have to big of viewing angle, or is it just the camera that has done that?
SIR-VRX
Postby SIR-VRX » Fri Jan 08, 2010 8:42 pm
It was taken on my camera phone Blake.
Looks much better IRL.
Blakey
Postby Blakey » Fri Jan 08, 2010 8:43 pm
yer but is doesn't explain the glare lol, is there any when you look at it? from the front?
