Help for Tadz0rz Mum
DJBOOBY
Postby DJBOOBY » Fri Oct 16, 2009 5:36 pm
You should change both rotors if needed
There and old mechanics saying what you do for one side do to the other
eg ball joints - tie rod ends
tadz0rz
Postby tadz0rz » Thu Nov 19, 2009 4:51 pm
Well.
Update for everyone, even though its nothing to do with the CJ..
I went to RDA today and picked up a set of pads and rotors for the fiesta. Got em all installed today, only problem i had was compressing the caliper piston. Since i didnt have the right tool to do it, i had to brunt it out and use my hands to compress it.
Took me all up about 2 hours (First time ive done it) and i took it out for a spin (without mum :shock: lol) Theres no real braking performance difference...Yet. The pads still gotta bed in then we'll see the proper results.
But, a big shoutout goes to ofey for helping me organise the rotors and pads for Mumz0rz. 6x LESS than what ford wanted to charge for the pads, rotors and labor AND i got experience on how to change brake pads and rotors lol. Thanks ofey, your a big help!!!!!!!
Postby LZY_EYE » Thu Nov 19, 2009 4:59 pm
A good trick if you don't have the correct tool to compress the calipers is a thin piece of wood, and a screwdriver for leverage... Better than using brute force :P
Good work on DIY :)
tadz0rz
Postby tadz0rz » Thu Nov 19, 2009 5:02 pm
^^ I sorta did that.
I used the old brake pad and used the pole from the car jack to level it, but, i actually found it easier to use my hands for some reason lol.
Postby LZY_EYE » Thu Nov 19, 2009 5:13 pm
Weird, I found the piston on the CJ quite difficult to press. Screwdriver did the trick :)
SIR-VRX
Postby SIR-VRX » Thu Nov 19, 2009 5:24 pm
The proper tool is like $10 at Repco :lol:
But I just use G-Clamps
tadz0rz
Postby tadz0rz » Thu Nov 19, 2009 6:42 pm
Yessss i knowww :P. I was contemplating going out, but, i was dirty like you wouldnt believe. Brake dust on the fiesta was a massive problem. Since the piston was at least moving i thought id stick it out like a man and not use tools like a girl :P
SIR-VRX
Postby SIR-VRX » Thu Nov 19, 2009 6:53 pm
Well considering the piston on a Fiesta is about 1/4 the size of the CJs, even my Grandma could push it back by hand :lol:
tadz0rz
Postby tadz0rz » Thu Nov 19, 2009 7:03 pm
You must have quite a grandma :P
SIR-VRX
Postby SIR-VRX » Thu Nov 19, 2009 7:06 pm
Users browsing this forum: Google [Bot] and 206 guests
