Lancer Bulb List!
MrCJ wrote:i tryed this and the leds don,t work lucky enough i picked them up from work for free the bulbes worked when i tested them at work so it wasn,t the buulbs it,s something to do with out headlight set up
You will need load resistors.
if you want to run white bulbs the Philips Crystal Vision are good there not ADR approved but the legal limit for Kelvin is 4300K and these are rated at 4300K but it,s to close to what it legal so they wont approve them
Illegal Kelvin range is when the lights become prominently blue, that is ~5500K+. Autobarn sells ULTRA design 9006 (HB4) 5000k halogens for $60 IIRC. The packaging claims to be E-marked (and hence ADR approved).
thats what i got in my car and there good have been pulled over a few times for RBT and the cops have said nothing about them but be warned there not cheap set me back $120 Philips do make ones that are ADR approved but there more yellow from memory there called BlueVision
Unlikely they'll mention anything about the lights unless its clearly illegal (i.e. blue/red in colour). There are a lot of people who get away with HID installs running 6000k setups in reflectors. Not condoning this, but unless the cop is having a bad day - you're probably going to be fine.
However if an accident is the cause of a non-ADR approved setup you're going to be in a bit of trouble.
does anyone know where i could get a set of Philips SilverVision T20 bulbs for the indicators in the headlight
I'm running some ULTRA SilvaTec's for the tail light indicators (same as front ones). About $12 or something from the UK.
I am looking for HID conversion kit for
Head light, low beam: (halogen bulb) 51watts bulb: 9006 HB4
There are a lot on ebay, but either 35w or 55w, not 51w. which one can we use?
http://www.ebay.com.au/itm/180901923987 ... 373wt_1399
http://www.ebay.com.au/itm/180954156056 ... 568wt_1321
hobba wrote:Thanks mate! I thought so. But after seeing the first post I just wanted to check cos it says ... Front side marker and parking light: 5watts bulb: WY5W 194 License plate: 5watts bulb: W5W 194 Wasnt sure if the wy5w was a typo or if it means the same as w5w.
they are the same, did it to mine with the same bulb, can get from supercheap auto.
can someone also answer my question earlier?
RAwannabe wrote:I am looking for HID conversion kit for Head light, low beam: (halogen bulb) 51watts bulb: 9006 HB4 There are a lot on ebay, but either 35w or 55w, not 51w. which one can we use? http://www.ebay.com.au/itm/180901923987 ... 373wt_1399 http://www.ebay.com.au/itm/180954156056 ... 568wt_1321
