*** Bluetooth Compatible Phones - List ***
- Mr Charisma
Mine works fine, as long as I don't want to initiate the call from the car. Receiving calls and dialing out from the phone work fine.
I have spoken to Mitsubishi, and they know about it, as does R&D in Japan. They may decide a firmware flash for the BT module is in order... but who knows if it will be for newer models or backdated to ours
- The X
Nokia 6121 doesn't work for outbound dialling. Everything else is fine.
I run firmware version V5.11 (21-04-08)
Also tested a 6121 from work with firmware V4.09 and that also had the same issues.
duce2278 wrote:ok so what ur saying is to answer and hang up a call you must use the phone rather than the steering controls?
When a call comes in, you can take it via the steering wheel as it is meant to be. The only thing which does not work for new Nokias is initiating the call from either the car's inbuilt phonebook or spelling out the number to the car...
Using the phone Itself to make the call works, and once the other person answers the handsfree tales the call from the phone.
Users browsing this forum: Majestic-12 [Bot] and 22 guests
