Hi Everyone - intro32
- Mystique
Sexy!
- bunnishiwa
My neck of the woods. Did you hit the flinders/merricks roads? Some beautiful driving down that side of the peninsula
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
- Lowered on Kings
hey! just read about the reverse not engaging and beeping. How often is that happening? That happens to me too. About once a month. I believe its the clutch not engaging properly so it takes a second or two for it to get into gear. Not an unknown thing from what i believe.
If you dont mind me asking what other problems are you experiencing? And which dealers have you gone to talk to them about it? Why did you need a gearbox replacement? thats very expensive isnt it?
As for ECU work, as someone said Beeble is the best person to talk to. Short of an actual dealership he's the best person... in fact he's better person to talk to then a dealership. At least you wont get a load of BS if you talk to him
-Cosworth Air Filter
-Evo X BOV
-Evo X Intercooler
-Grimmspeed 3 port
-Ultimate Racing UPICP & LICP
-Evo X BOV
-Evo X Intercooler
-Grimmspeed 3 port
Momengah wrote:hey! just read about the reverse not engaging and beeping. How often is that happening? That happens to me too. About once a month. I believe its the clutch not engaging properly so it takes a second or two for it to get into gear. Not an unknown thing from what i believe. If you dont mind me asking what other problems are you experiencing? And which dealers have you gone to talk to them about it? Why did you need a gearbox replacement? thats very expensive isnt it? As for ECU work, as someone said Beeble is the best person to talk to. Short of an actual dealership hes the best person... in fact hes better person to talk to then a dealership. At least you wont get a load of BS if you talk to him
Hi Momengah, the reverse not engaging problem happens all the time for me, it usaly happens just after starting the car and putting it in reverse ( hot or cold start's ), but it has happened a couple of time's where i pull into a car park without turning the car off and i try and reverse. This has only happened with the new gearbox not my old one that was stuffed, go figure lol. Other main problem's im experiencing are most since day 1 motor detonation, motor has a knocking noise ( NOT injector noise! it sounds like something is slopping around in there ) gearbox problem's ( chattering, long lag time's between gear change's, reverse problem's, etc ) it has some steering problems as well that new tires and a wheel alignment can't fix ( very heavy steering when turning right and when turning left it feels like the front wheel is collapsing on it self, its hard to explain u need to drive it, even the tire place that was doing my alignment said that there was something wrong with the steering but they couldn't find the problem.) Very poor fuel economy but u have to expect that when the car isnt running properly. Both driver's and passenger window's leak, massave boot rattle but cant find where it's coming from and no it's not because of any sub woofer's.
The gearbox saga lol :On the first drive home after picking up the car i noticed a loud noise when i stopped at traffic lights i had no idea what it was or where it was comming from, I get the car home and at first thought it sounded like the noise was coming from the turbo, so i took the car back and then i was told that the noise was normal for this car and there was nothing wrong with it ! I told the dealer i didnt spend all this money on a brand new car to sound like something was about too let go ( funny thing is when i took the car for a test drive 3 days earlier that was NO noise at all ! ) it was embarrassing to drive, the noise was that loud when u stop people look at u with that strange look like " wtf is wrong with your brand new car " So after the dealer wanted nothing to do with it i took it to another service center and the service manager had a RA and i showed him what my car was doing and what it sounded like and the first thing he said to me was " Ummm... that's not good, i don't know what the problem is but mine dosnt do that and iv never herd that before" So he booked me in straight away to get it looked at. I was told that they didnt have much experience with RA but they wanted to fix the problem, so they stripped down my motor and i meen stripped it down to the block! in search of the problem but didnt find anything, at this time i didnt want the car, it was f**ked. Anyway they pulled apart the turbo and there was nothing wrong with it, and last they pulled down the gearbox and seen that there was a few things wrong with the clutch and some other components to do with the clutch, basically the clutch looked like it had been cooked. I was told that both clutch and gearbox needed to be replaced asap, so they ordered a new gearbox and clutch and installed them. When i picked the car up the first thing i noticed was that the motor sounded like something was slopping around and when driving it was detonating badly ( this could have been happening before i got the gearbox fixed but i couldn't hear the motor over the gearbox noise ), so i took it back and told them about the motor noise and detonation, but they didn't have the right computer equipment for the RA to check to see whats was going on with in the ecu map ( yes this was an authorized RA dealer / workshop ) I really appreciated the effort that this Mitsubishi service centre had done for me going to the lengths that they did to help me out with my gearbox, but since they dont have the knowledge or equipment to help with the motor problem's i feel stuck with this problem as i dont want to take it back to the dealer i got the car from because they will just deny that there's anything wrong with it, so now im not wanting to drive the car becuse iv seen what happens to a turbo motor that detonate's. I asked if i could put the car on a dyno to get it all checked out and i was told that " could " void my warranty. The only other thing that was suggested to me was to take it back to another dealer that has the equipment needed to check what was going on, problem is where is a good dealer / workshop that is knowledgeable and not just going to deny there is problem because they can't be bothered fixing something under warranty ?
So any way end result as it stands now i have had this car for almost 3 years that after the first week of owning it the motor, turbo & gearbox had been pulled down multiple issues with other part's of the car its self. Iv only done 10,000 km's in 3 years most of those km's were going too and from getting it fixed. Now that iv found this forums the future looks brighter just knowing that there are people that know what they are doing and i might not be as stuck as i thought
Mate have u raised this issue with mitsubishi HQ. this is unacceptable that your car has factory warranty and they are not fixing the issues properly and the car doesn't drive like a new car should. They should fricking give you a new car.
Why don't you complain to fair training?
Users browsing this forum: No registered users and 82 guests
