Pretty keen to get them on tomorrow.
I did notice that the manual said "MY12-onwards" so that was a bit disconcerting.
the plug location changes from pre 2012 cars because the etacs module is physically different but the plug you need is still there.dannyboi wrote:Thanks, Im going to try it this morning. So what is the difference with the ETACS, specific to this install? Plugs/ports are in a different location or missing altogether?
Adamacaus wrote:I also had a bit of trouble behind the glovebox when installing the DRLs in my 09 but I found the plug I needed behind the main board. It inserts upwards.
Adamacaus wrote:The DRLs should operate as follows: 1) Engine off - nothing (obviously) 2) Engine on, all lights off - DRLs on at maximum 3) Parkers, headlights, high beams - DRLs dim but remain on
