Got my fog lights yesterday yea!!!
tadz0rz
Postby tadz0rz » Sun May 17, 2009 8:40 am
How we going with this install? Have you got them in yet?
criteek
Postby criteek » Thu Jul 02, 2009 11:56 pm
Ive had mine laying around for months and finally put them in today while installing my angel eyes, it's actually not that hard to do, and theres a spot where u can get thru the firewall, behind where the switch will go :)
blanka
Postby blanka » Fri Jul 03, 2009 8:25 am
oh ok that been said i might attempt mine tomoro cos its been sitting there for like a month now lolz
Uchiha Itachi
Bandit
Postby Bandit » Fri Jul 03, 2009 9:41 am
Hi Criteek - is it possible to get a picture of the existing firewall hole - I wouldnt mind using an existing hole to get my UHF aerial cable through there to the dash.....
ClubCJ's first Sportback
Dummer
Postby Dummer » Fri Jul 03, 2009 12:31 pm
Above the accelerator pedal, or through the wheel wells is where you'll find the holes.
criteek
Postby criteek » Fri Jul 03, 2009 11:54 pm
Yep, if u unscrew that panel where the switches are and look to the firewall, u will see theres and area of the cloth material which has been cut so u can pull it back, under there is a hole that leads out to the engine bay
