Brakes, brakes, running out of brakes.
- Mitsiman
The problem with squeaking etc is not so much the pads, bt the rotors. Factory Mitsubishi rotors have always been bad, and when you put good ceramic pads on them, they just become horrible sometimes. I highly recomend that if you do a RDA rotor / EBC Pad combination you won't go backwards
For urgent replies to PM's contact via phone
Dont get greens for an RA, get the Reds. Reds still perform perfectly fine on the lancer from cold. Get a stop or two into them though and they will ave alot more bite.
I have had no wears issues after doing around 30,000km+ on my RDA Slotted and Dimpled rotors with the EBC Red Stuff pads. They would have also had quite a few heavy heat cycles over the last 12+ months aswell...
Check out our latest sponsor GSL RallySport. They stock a whole set of different types of brakes.
GSL RallySport Brakes
GSL RallySport thread
Blitz Air Filter | RPW Stage 1 ECU Flash Tune | UR Front Tower Strut Bar | UR Rear Lower Bar
Alpine iDA-X305 headunit | LED Taillights | VG Sharkfin Antenna
