New Spray Product Idea for Front Bumper
Ozie
Postby Ozie » Wed Apr 29, 2009 3:33 pm
thats saves me a trip thanks mate.
we need to order it in from OS.
criteek
Postby criteek » Wed Apr 29, 2009 3:40 pm
Yeah, the guys at TJM Dandenong seemed to know all about it so it was good, just a shame really.
Shipping may hurt bringing these in, as they can't travel by air
Maybe we should try the Export contacts on this page:
http://www.plastidip.com/diy_where_to_buy.php
edit:
just a quick and dirty test with this stuff, it came off pretty well
test #001 (one coat only)
aussie027
Postby aussie027 » Wed Apr 29, 2009 5:37 pm
Thanks Criteek,
There is a primer for use on metal to make it stick better.
I was mainly concerned about just spraying over an unprepped high gloss clearcoat finish.
I may go and get a tin or 2 of the black as only one expensive place here in Perth has any apparently and everyone back east has said it is not available.
tadz0rz
Postby tadz0rz » Wed Apr 29, 2009 5:39 pm
I see it still comes of but im still unsure about the stuff. Im sure it works perfectly but i couldnt find myself trusting it over a long period of time. especially on paintwork
criteek
Postby criteek » Wed Apr 29, 2009 5:50 pm
it's actually stuck on pretty well, and that's just with one coat.. i was pretty impressed with it
bye2u
Postby bye2u » Wed Apr 29, 2009 7:11 pm
alright i got my can in black and will try it sometime in the week...
Bobcat_GTS
Postby Bobcat_GTS » Sun May 03, 2009 3:27 pm
I've already done my bumper with it. Worked well too. I posted a pic here: http://clubcj.net/viewtopic.php?t=992
aussie027
Postby aussie027 » Sun May 03, 2009 4:06 pm
Hi Bobcat,
Did you sand the surface 1st or just clean and spray on???
How many coats and time in between coats???
How much did you use to do the number of coats you did??
Lastly, my big concern is will it easily start to peel off if you rub over an edge??? if that is going to be a big potential problem I would rather paint it instead as I do not want to have to redo it. The black colour is apparently almost completely unavailable here in Aust and it is more than 3 times the US price.
Mizta B
Postby Mizta B » Sun May 03, 2009 10:38 pm
This stuff looks the goods
But if it is that hard to find I'll get mine done the old fashioned way at my mate's panel shop............
Merlinised....
Bobcat_GTS
Postby Bobcat_GTS » Tue May 05, 2009 3:22 pm
aussie027 wrote:Hi Bobcat,
No sanding needed, just clean it first. If you sand it, then it might not be removable, or as removable. I put on about 4 coats since that's what the directions recommend. It says wait 30 minutes between coats, but I didn't wait that long. You just don't want to get too much wet paint on it at once or it will run. I'd say one can would be enough to do it several times over. I had to re-do it once, and I still had some left after the second time so I coated my license plate frame too and the can still isn't totally empty. I'm sure if something scratched it hard enough it would damage it, but it won't just peel off by itself. I'm wondering how it will hold up to the pressure washer at the car wash though. lol If you want something permanent I'd go with paint, but I like this stuff because it looks just as good and it can be removed or re-done easily. It sucks that you guys are having a hard time finding it and that it's so expensive. Maybe I should pay you guys a visit and smuggle some with me. :wink:
aussie027
Postby aussie027 » Tue May 05, 2009 3:30 pm
Hi Bobcat, Thanks Sooooo much for your reply, I was just about to go and get some right now while I still can get it although at the high price.
Did you mean 1 can would be enough to do the 1 JOB,ie the entire 4 coats,
several times over if you need to redo it???
Bobcat_GTS
Postby Bobcat_GTS » Wed May 06, 2009 1:57 pm
aussie027 wrote:Did you mean 1 can would be enough to do the 1 JOB,ie the entire 4 coats,
Yep, one can is plenty to do it several times if it gets messed up or just needs to be re-done over time. You guys that live close enough could chip in on a can and do several cars. :wink:
aussie027
Postby aussie027 » Wed May 06, 2009 2:38 pm
Thanks Bobcat.
I bought 2 cans yesterday and will start pulling grill off and masking car today.
Now that yours is dry and cured how resistant does it seem re edges not lifting if rubbed etc. IE is it sticking well????
Numerous reports I read said it is very resilient.
I hope so.
criteek
Postby criteek » Wed May 06, 2009 3:08 pm
send me a can aussie lol
aussie027
Postby aussie027 » Wed May 06, 2009 4:08 pm
keep trying the main distributor guys.
I hope I am not wasting my time and money buy using this instead of paint,esp on painted bumper centre.
I have pulled grill off and have 1st coat on now. Will post all details and pics when done and reassembled.
Users browsing this forum: Google [Bot] and 36 guests
