Installed chrome fog light rings from RyanMK, OEM mudflaps and new headlight protectors.
I couldn't use either of the bottom screws on the mudflaps; the plastic they screw into threaded out very easily.
Hopefully they'll be fine with just two screws and tape.
Also used some touch up paint on a few stone chips around the top grille.
It will be interesting to see if using touch up paint on a silver car is worth it, because it could make the chips even more obvious.
The mod list can only grow from here
dubdocker wrote:I couldnt use either of the bottom screws on the mudflaps; the plastic they screw into threaded out very easily. Hopefully theyll be fine with just two screws and tape
I had the same problem. All I did was bought slightly wider and longer screws from Bunnings. Worked a treat. PM me if you want to know the exact size of the screws, I still have some lying around.
- DORA_ANNE
I had my 90.000k service today @ $530 , My Little girl is getting a bit high on the K's But she's still going strong & Mitzi fitted up my new Bosch Wipers "Thanks To Ofey's GB The wipers are great ..... And Mitzi found I had a leaking RHF Shock so she goes back in next week again ..... And Iam getting a new windscreen replaced T'Morrow after a 4WD Threw up a rock the other day and I have a large crack across the screen ..
Driving Home Felt so much Better after the Service
PS ..Your Seats look Great Shane
got halfway through fitting a new passenger side windscreen washer nozzle
and then had to go and make up a cabin 4 a last minit booking!
now its f-in dark!
arse
now its f-in dark!
arse
mods 2 date =
k&n h/f filter
darkest legal tint
avanti tallons 18/8"
federals ss 235/40
hell braided brake lines
blaaack calipers
whiteline sport swaybars F/R
bendix ultimate b/p's front
RA calliper stickers
red badges
boost gauge
RA peddles
more on their way...
k&n h/f filter
darkest legal tint
federals ss 235/40
blaaack calipers
red badges
boost gauge
RA peddles
Today I picked up a new drivers side air vent. I found the old one kept pointing at the ceiling after a while(thanks Sleeper). Mitsubishi gave me a new one under warrantie.
I picked up a Ralliart battery cover. I will paint it and fit it soon.
When I got home from work my centre arm rest with twin shelf from Japan parts was there. I fitted that so another hiding spot. It is a great spot to hide car part receipts.
- shamoo
aspir3 wrote: When I got home from work my centre arm rest with twin shelf from Japan parts was there. I fitted that so another hiding spot. It is a great spot to hide car part receipts.
just hope nina doesnt read this cos now she will know where to find the receipts for what you have done to ur car troy
@ Ryan they say there OEM but really who knows forsure they fit up really well. The only bad thing is the switch for the cabin is a lil cheap and nasty here's the link http://www.ebay.com.au/itm/2007-2010-MI ... 930wt_1141
Users browsing this forum: Google [Bot] and 26 guests
