Ebay Thread
- The X
Melbournites! Possibly a Recaro seat... but not the Evo/Lancer rails, it has Silvia rails! So you'll have to source the rails, so that will be an extra expense...
The passenger seat is in ghastly condition, the air bag is blow and has what looks to be a nasty cigarette burn/tear on the rear with visible rust, etc.
There are no pictures of the apparently "good condition" driver seat.
So buyer beware and I'd urge you ask for photos or inspect it.
So caution on this one......
http://www.ebay.com.au/itm/evo-x-recaro ... 19ce5aa3d8
- The X
INVUR-1 was after some VRX rims in Melbourne... a little damage.. but here that are.
http://www.ebay.com.au/itm/18-Mitsubish ... 3a718b6f5b
OR some one up in QLD (Bribie Is) want some brand new in box VRX rims?
http://www.ebay.com.au/itm/2008-Mitsubi ... 43add95374
Or Tasmania.... anyone travelling down to Tassie that cam bring them back.
http://www.ebay.com.au/itm/Mitsubishi-L ... 3372ce55d7
Or if you're in Sydney and just need a spare
http://www.ebay.com.au/itm/1x-Mitsubish ... 2ebc262dbf
- Speedie
Anyone in Sydney want a sub
http://www.ebay.com.au/itm/Lancer-Cj-Vr ... 3cc3649db1
- malkinfalcon
- Lancer ES/EX
I know that many people are interested in aftermarket foggies...Bought these about a month or so ago and they're working perfectly...yes, you're paying just a tad more for these than the other foggy kits but I can assure you that these are quality
http://www.ebay.com.au/itm/170607299786 ... 268wt_1037
That can't be an ES !
- malkinfalcon
- Lancer ES/EX
ALSO...
Some EVO X rims for a pretty good price
http://www.ebay.com.au/itm/120873085718 ... 500wt_1287
- ripflare10
Found this in my ebay searches.....Anyone in the Liverpool Sydney area after a Lancer Cj Vrx Factory Plug In Sub Woofer Rockford....$10 is the current bid
http://www.ebay.com.au/itm/Lancer-Cj-Vrx-Factory-Plug-Sub-Woofer-Rockford-/260976188849?_trksid=p4340.m263&_trkparms=algo%3DSI%26its%3DI%26itu%3DUCI%26otn%3D18%26pmod%3D250989457732%26ps%3D63%26clkid%3D6934530050052178761
Also for the major enthusiast
Mitsubishi Lancer Sedan Steering Wheel Mouse pad lol
http://www.ebay.com.au/itm/2011-Mitsubishi-Lancer-Sedan-Steering-Wheel-Mousepad-Mouse-Pad-/110839681910?pt=LH_DefaultDomain_0&hash=item19ce8f5376
ripflare10 wrote:Found this in my ebay searches.....Anyone in the Liverpool Sydney area after a Lancer Cj Vrx Factory Plug In Sub Woofer Rockford....$10 is the current bid http://www.ebay.com.au/itm/Lancer-Cj-Vrx-Factory-Plug-Sub-Woofer-Rockford-/260976188849?_trksid=p4340.m263&_trkparms=algo%3DSI%26its%3DI%26itu%3DUCI%26otn%3D18%26pmod%3D250989457732%26ps%3D63%26clkid%3D6934530050052178761 Also for the major enthusiast Mitsubishi Lancer Sedan Steering Wheel Mouse pad lol http://www.ebay.com.au/itm/2011-Mitsubishi-Lancer-Sedan-Steering-Wheel-Mousepad-Mouse-Pad-/110839681910?pt=LH_DefaultDomain_0&hash=item19ce8f5376
Does anyone know if this sub would fit in a 2008 VR?
- malkinfalcon
- Lancer ES/EX
Cut off the factory connector.
Green is L+,Yellow is L-, Blue is R+, and Red (or in some cases White) is R-
Get an aftermarket amp, input will be left and right rear speakers (tap into the +/- wires from each speaker, 4 wires in total), amp may have line level convertor built in so just wire up the inputs, amp should then output +/- for each channel, Wire up the sub
Glenn wrote:Cut off the factory connector. Green is L+,Yellow is L-, Blue is R+, and Red (or in some cases White) is R- Get an aftermarket amp, input will be left and right rear speakers (tap into the +/- wires from each speaker, 4 wires in total), amp may have line level convertor built in so just wire up the inputs, amp should then output +/- for each channel, Wire up the sub
I love you.
Thanks heaps, I was thinking of just reselling it and getting another sub now i can have the snug fit and boot room
- malkinfalcon
- Lancer ES/EX
Lucky, i was considering bidding
Very cheap pair of VRX rims in QLD, id get them but i dont think i really need them
http://www.ebay.com.au/itm/18-Factory-2 ... 43adfa4e8b
Users browsing this forum: Google [Bot] and 81 guests
