Postby Mitch » Thu May 05, 2011 7:07 pm
ofey wrote:Fixed it.
problem wasn't mitch. It was the post by JaCe
so what caused it to go like that ofey
Postby ofey » Thu May 05, 2011 7:11 pm
incorrect code... . Should I simulate it for all to see?
tadz0rz
Postby tadz0rz » Thu May 05, 2011 8:48 pm
jerryme wrote:My sticker came and I put it on :D
PLEEAASEEE TELL ME WHERE YOU GOT THIS D: I NEED ONE!!!
Postby ofey » Thu May 05, 2011 9:14 pm
Postby aspir3 » Sat May 07, 2011 7:48 pm
Today I fitted my throttle body back on my car.
I removed it and machined the bore out from 57mm to 61mm. A new butterfly was machined as well. This is the tricky part. This is now the same size as the inlet manifold.
I started the car and it runs fine, just like before.
I soon will put the car on the dyno and hope to see some more power improvements.
BrownSound
Postby BrownSound » Sun May 08, 2011 4:30 am
Decided that I wanted to be able to dock my iphone... Sadly though I managed to scratch the plastic being an idiot so now its crudely painted.... Still looks good in my opinion (from afar at least).
shaine
Postby shaine » Sun May 08, 2011 1:29 pm
Removed decals
ENJOY!! (cj-black)
Postby aspir3 » Sun May 08, 2011 5:18 pm
Today I fitted a new drivers seat back leather cover. The old one had scuff marks worn through the leather from me getting in and out of the car.
I also replaced the rear left hand door seal as the old one had shrunk.
Both were replaced for by Mitsubishi under warranty. They were going to fit them but I preferred to do it myself to make sure it was done right.
Postby ofey » Sun May 08, 2011 5:25 pm
Troy can you send me any receipt to show that your dealer replaced yours through warranty? Mine has those scuffs as well.
Postby aspir3 » Sun May 08, 2011 5:32 pm
ofey wrote:Troy can you send me any receipt to show that your dealer replaced yours through warranty? Mine has those scuffs as well.
No sorry. They just gave me the seat cover with no paper work.
I feel it is an issue with the leather seats as Sam has them to and he has low kilometres on his car as well.
Once they inspected my seat they were happy to replace the seat cover without any issue. It was easy to fit to. Took me about 30 minutes.
Meaty
Postby Meaty » Sun May 08, 2011 8:06 pm
so does that mean you have a leather seat cover lying around now ..?
Postby aspir3 » Sun May 08, 2011 8:09 pm
meaty wrote:so does that mean you have a leather seat cover lying around now ..?
Yes. It will be good to have as I can use it later to fix any other wear marks.
Postby ofey » Sun May 08, 2011 8:12 pm
Do you then have pictures of your scuffs?
Postby aspir3 » Sun May 08, 2011 8:37 pm
Sorry it is not a good picture. I need to do in in natural light. It could not be seen with the flash at all.
You can see it is only small area but it has worn through the outer layer of the leather.
BrownSound
Postby BrownSound » Sun May 08, 2011 9:17 pm
Gave her a nice wash and stuck this on -
Users browsing this forum: No registered users and 77 guests
