Knowing about the Evo X Spoiler
- nickbutterz
- Tarquin
TheRents wrote:ok so lets look at what we know
is ABS
Blow moulding
it has encapsulated nuts
it comes in two peices
it is hollow
it has some sort of alloy in the middle
and it has more than 4 bolts
2014A - Aircraft Aluminium.....
Probably in a honeycomb style shape or lattice shape... possibly even from a casting process....? This would be in the internal structure of the wing.....
The two parts of the wing (top and bottom) and secured onto this mental with screws... possibly even over 20-30 in that size wing.
The wing would be secured to the boot of the car with 3, maybe 4 bolts either side, screwed into tapped screw mounts in the bottom section of the wing and boot interior.....
the 'step up' angle in the wing design would also give it aero properties, but it's probably more for its own structural stability when under load (at speed) but more importantly when at rest.
Cars spend significantly more time not going anywhere and if you've see a saggy rear wing, you know what I mean...
Seeing the picture and only skimming the thread for info, I first said the two halves of the wing - if made from metal, it would be pressed aluminium sheets - like how they do for car panels...
Or, if a plastic compound or similar, then either an injection moulding process (90% of most car interiors now-a-days) or perhaps and blow method as listed.
Tarquin wrote:TheRents wrote:ok so lets look at what we know
is ABS
Blow moulding
it is hollow
Umm.... 2014A aluminium are not for aircraft. commond use for aircraft are 2024-T4 7075![]()
Honeycomb are only apply for floot panel in aircraft, but not for spoiler![]()
Nope:
Ummm...... yes is 3 screw. but not 4 screw.![]()
tapped screw mounts yes, but someone here already have it.
nope, is not for aero properties
hahaha...... yes is for stability when under load.
1 point
yeap i know![]()
but no point
Shadows wrote:Shadows wrote:Shadows wrote:American Heroes
Nickbutterz 1 point
Aussie Warrior
Ozie 0.5point
Matt 0.5 point
TheRents 0.5 point
Canadian Fighter
Later update.
Nickbutterz 1 point
Sabaunited 0.5point
Aussie Warrior
Ozie 0.5point
Matt 0.5 point
TheRents 0.5 point
Tarquin 1 point
Canadian Fighter
SabaUnited
SabaUnited
Shadows wrote:SabaUnited wrote:6111 aluminium alloy
Very close Mr. sabaunited.
Actual should be AA6111-T4.
Thank you
0.5 Points![]()
Aw thanks shadows. I appricate it even though I already have the visors lol. This is actually a really interesting topic, I had no idea how much goes into making a spoiler. Does the process have anything to do with corrosion resistance and precipitation hardening?
- nickbutterz
Ozie wrote:Shadows wrote:i am quite disappointed with you Nick.![]()
don't you want to win the windows visor? otherwise i have to keep it for myself. hahahahahaha.....
we all want to win it,
but yo are leading us on a wild goose/Singaporean tiger chase! lol.
you need to be Einstein to work it out!!!!
hahahaha
