Did you know...?
Nick07
Postby Nick07 » Sun Aug 21, 2011 10:32 pm
You can't access the menu in the middle of the speedo without having the handbrake engaged. Also you can turn the beep off and set it to give you different averages.
brent0013
Postby brent0013 » Tue Oct 11, 2011 9:57 pm
did u know that all the automatics in the lancer n/a range have a higher fuel consumption....
except for the vrx sedan, having 8.9L manual and 8.8L automatic
Gleno
Postby Gleno » Wed Oct 12, 2011 9:03 am
Why can't we have the long term avg speed and fuel (b) set to be on our screen all the time?? If I go to manual mode to find out what the long term avg speed and economy are, it will go back to the normal mode when ignition is switched off and on again.
Mitsi
Postby Mitsi » Wed Oct 12, 2011 4:47 pm
Did you know..
If you are in the car and lock the doors, you can unlock them again by opening the door
BTW - this thread rocks. Should be sticky if it's not already
2010 Lancer Ralliart <3
Postby bd-850 » Sun Oct 16, 2011 10:37 am
there has been alot of talk about the Speedo being out therefore throw your Ks out aswell, UNTRUE
tested it by using the Speedo Check signs that they have on the side of the road, (mine is about 0.2ks out over 5ks) plus if you reset the Fuel Average while driving you will see that the computer speed reads lower than the speedo.
Gleno
Postby Gleno » Sun Oct 16, 2011 5:49 pm
Which equates to 1km in every 25km. Over a period of time it all adds up.
Gleno
Postby Gleno » Sun Oct 16, 2011 5:51 pm
But in all fairness I'm being picky, just comparing it to my camry and commodore which had more
Accurate speedo.
squala
Postby squala » Wed Feb 22, 2012 6:21 am
Lancers equipped with factory alarm will actually activate the system if you jack up the car with the doors locked.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
SXLancerMum
Postby SXLancerMum » Wed Feb 22, 2012 11:17 am
Did you know..... that it's not just the Lancers. All newer cars actually go slower than the speedo says. Some are out by 5km/hr or more. That's probably one of the reasons that older cars zip past newer ones on the highway. The newer ones have their cruise control set on 100 for example but they are actually doing 95-97. The older cars (my old Bubble for instance) have more accurated speedos and are actually doing the 100. It just looks like they're speeding past because they're on the speed limit and you're actually below it.
Hubby used to go along at 110 on the Freeway and I'd be behind him and my Bubble would be doing close to 100. Mine was right. The Craptiva was wayyyyy out. I'd then get into trouble for going past him and pulling away. He'd ring me and up me. I used to tell him to keep up because I was the one actually doing the speed limit.
I usually set my CC at 103 to make up for that. A hell of a lot of people still rush by me though. Last week going along the Golden Hwy between Sandy Hollow and Singleton I was on 103 in a 100 zone and people were past me and gone. Obviously the speed limit is just a guide that you don't have to stick to. Or be anywhere near.
cody_au
Postby cody_au » Wed Feb 22, 2012 11:31 am
I have an old Festiva and I've tracked it with a GPS to see the speed accuracy is under by 1-2/100km per hour. But with underinflated tyres, it can increase to around 5/100km.
alterego13
Postby alterego13 » Wed May 09, 2012 1:25 am
Did you know....(well I didn't..so here we go)
If you long press(approx 2-3 secs.) the 'mode' button on your steering audio controls it switches the Sound system on/off..!
Dirtee
Postby Dirtee » Wed May 09, 2012 9:12 am
Probably been mentioned before...
If you drive in temperatures below 3'C, the small screen on the dash lights up yellow cautioning you that there is icy road conditions.
2010 Lancer Es - My Ride
Wanna be customiser!!
ACT Rep 2012
CJLancerInstalls - How-To's!
Cammo00
Postby Cammo00 » Wed May 09, 2012 1:04 pm
Yer I got that lately. Mostly when braking and driving on a well warn road. Says possible icy road
Love That Car. (cj-blue)
Return to “ClubCJ Talk”
Users browsing this forum: Google [Bot] and 41 guests
