*CLOSED* EBC Pads & RDA Rotors
For all ClubCJ Members.
SIR-VRX
Postby SIR-VRX » Fri Sep 11, 2009 9:47 am
small disks? Mine are 300mm diameter. That is stock size, and the stock brakes are good enough anyway, just need slight upgrade.
And if we were to increase the disk size, we do run into trouble relocating the caliper etc
So its just easier to upgrade to better disks and pads, as they're still daily drivers anyway.
Joog123
Postby Joog123 » Fri Sep 11, 2009 9:55 am
SIR-VRX wrote:small disks? Mine are 300mm diameter. That is stock size, and the stock brakes are good enough anyway, just need slight upgrade.
lzy_eye wrote:You have to make the discs the same diamater as OEM, as you say due to the calipers.
Remember these wheels are 18" so it makes the discs look pretty small. By comparison the CJ has pretty decent sized brakes.
I wasn't sure, which is why I asked about it :)
The 18's just make them look ridiculously small, even smaller if you had after market wheels that let you see more of the brakes.
SIR-VRX
Postby SIR-VRX » Fri Sep 11, 2009 10:35 am
only the es or vr brakes look small :P
Joog123
Postby Joog123 » Fri Sep 11, 2009 10:48 am
SIR-VRX wrote:only the es or vr brakes look small :P
Nah, VRX brakes are still puny. It's just the OEM wheels that hide this.
http://img262.imageshack.us/img262/56/amg2ea1.jpg
:wink:
Postby LZY_EYE » Fri Sep 11, 2009 10:54 am
So you are comparing a minimum $100,000 AMG merc to a sub $30k Lancer!!!
I can go and spend big bucks on Brembos or AP's as well and have bigger disks, but at the end of the day this is my daily drive and even my ES stops pretty good for what it is :)
Joog123
Postby Joog123 » Fri Sep 11, 2009 11:08 am
I never mentioned cost, I mentioned size and how it appears to the eye :)
Postby LZY_EYE » Fri Sep 11, 2009 11:14 am
I know that, I was just giving you a hard time :P
I can't wait to get these on... hopefully this weekend!!
Postby ofey » Fri Sep 11, 2009 1:20 pm
Well done now, I'm locking this thread till the next brakes and rotors buy.
[Update 2 Nov 2009]
Just for everyone to know, a set of rotors and Greenstuff pads as I bought for most VRXs and above were A$430.
The updated price to this is now A$450.00 and are available anytime.
Postby ofey » Sat Aug 21, 2010 10:50 am
hi all, we're back with R2 of this group buy.... . See first post of thread for details... .
Postby aspir3 » Sat Aug 21, 2010 11:04 am
Ofey can you update the list with RA brake discs and pads as they are different to VRX?
I would be interested in those.
Postby ofey » Sat Aug 21, 2010 1:27 pm
For those who have RAs or their callipers, It's a very confusing issue for the pads. Please see:
For RA sizing issues, please read:
Front/rear Brake Info
or
RalliArt Brakes
or
2009 Ralliart - Brake Guide
If you can figure things out, please provide:
RA Pads:
Front-
Greenstuff = ???
Redstuff = ???
Rear-
Greenstuff = ???
Redstuff = ???
RA Rotor size
Front =??
Rear = ??
exaltd
Postby exaltd » Wed Aug 25, 2010 12:55 am
Interested. Hope this one will go through.
Postby LZY_EYE » Wed Aug 25, 2010 7:45 am
Just to give you guys a heads up.
If you are looking at doing any track days etc, I would strongly recommend the red stuff from the EBC range.
I had the green stuff from the last group buy and they just couldn't cope. If you are not being too hard on your brakes, the green stuff will certainly suffice.
tadz0rz
Postby tadz0rz » Wed Aug 25, 2010 7:53 am
I will EOI on some front slotted and dimpled rotors and green stuff pads. Ill confirm later...
When is this likely to go ahead?
Postby ofey » Wed Aug 25, 2010 8:04 am
30 September. This is September's group buy... .
